- Mute
- Permalink
- Report
I've modified the sample gear script to use Modular inputs. All seemed ok until I tried to produce a gear with 50 teeth and you get this error message.
I then tried the original gear script and it gives the same error. I think the problem happens when the involute form goes below the base circle.
I've tried to debug the program but I don't know a lot about Python and can't figure out how to run a debug on this program.
I've attached the modified script you need to extract the zip file "SuprGearModular.py" and the SpurGear subdirectory to
C:\Users\Your User Name\AppData\Roaming\Autodesk\Autodesk Fusion 360\API\Scripts
In the line above replace "Your User Name" with your user name.
The scripts run OK as long as you have less than about 35 teeth.
Mark.
Mark Hughes
Owner, Hughes Tooling
