Fusion crashes with a certain model.
07:15 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Fusion crashes with the model "One building near Ekaterinburg" ( https://fusion360.autodesk.com/projects/one-building-near-ekaterinburg ) after running this code in the third or the fourth time.
If it is clear, please, help with it. Otherwise, I just report this.
import adsk.core, adsk.fusion, traceback from xml.etree.ElementTree import Element, SubElement, tostring def run(context): ui = None try: app = adsk.core.Application.get() ui = app.userInterface quality = adsk.fusion.TriangleMeshQualityOptions.LowQualityTriangleMesh root = Element('geometry') listComp = adsk.core.ObjectCollection.create() for occ in adsk.fusion.Design.cast(app.activeProduct).rootComponent.allOccurrences: listComp.add(occ) listComp.add(adsk.fusion.Design.cast(app.activeProduct).rootComponent) for l in listComp: if l.classType() == adsk.fusion.Occurrence.classType(): bodies = l.component.bRepBodies matrix = GetMatrix(l) if l.classType() == adsk.fusion.Component.classType(): bodies = l.bRepBodies matrix = adsk.core.Matrix3D.create() for body in bodies: if body.isVisible: for face in body.faces: meshCalc = face.meshManager.createMeshCalculator() meshCalc.setQuality(quality) triangleMesh = meshCalc.calculate() if triangleMesh: coordinates = triangleMesh.nodeCoordinates indices = triangleMesh.nodeIndices normalVectors = triangleMesh.normalVectorsAsDouble mesh = SubElement(root, 'mesh') materialXML = SubElement(mesh, 'material') color = SubElement(materialXML, 'color') materialID = SubElement(materialXML, 'id') r = SubElement(color, 'R') g = SubElement(color, 'G') b = SubElement(color, 'B') opacity = SubElement(color, 'opacity') shininess = SubElement(materialXML, 'shininess') reflective = SubElement(materialXML, 'reflective') transparency = SubElement(materialXML, 'transparency') properties = body.appearance.appearanceProperties if properties: colorprop = properties.itemById('metal_f0') if not colorprop: colorprop = properties.itemById('opaque_albedo') if not colorprop: colorprop = properties.itemById('transparent_color') if not colorprop: colorprop = properties.itemById('concrete_color') if colorprop and colorprop.value: materialID.text = str(body.appearance.id)+"-"+str(colorprop.value.red)+str(colorprop.value.green)+str(colorprop.value.blue) r.text = str(colorprop.value.red) g.text = str(colorprop.value.green) b.text = str(colorprop.value.blue) opacity.text = str(colorprop.value.opacity) shinprop = properties.itemById('surface_roughness') if shinprop and shinprop.value: shininess.text = str(shinprop.value) reflprop = properties.itemById('opaque_f0') if reflprop and reflprop.value: reflective.text = str(reflprop.value) transpprop = properties.itemById('transparent_ior') if transpprop and transpprop.value: transparency.text = str(transpprop.value) vertices = SubElement(mesh, 'vertices') for c in coordinates: vertice = SubElement(vertices, 'vertice') c.transformBy(matrix) x = SubElement(vertice, 'x') x.text = str(c.x/-100) y = SubElement(vertice, 'y') y.text = str(c.z/100) z = SubElement(vertice, 'z') z.text = str(c.y/100) normals = SubElement(mesh, 'normals') nNormals = 0 for c in coordinates: normal = SubElement(normals, 'normal') x = SubElement(normal, 'x') x.text = str(normalVectors[nNormals*3]) y = SubElement(normal, 'y') y.text = str(normalVectors[nNormals*3+1]) z = SubElement(normal, 'z') z.text = str(normalVectors[nNormals*3+2]) nNormals+=1 triangles = SubElement(mesh, 'triangles') for t in range(triangleMesh.triangleCount): triangle = SubElement(triangles, 'triangle') a = SubElement(triangle, 'A') a.text = str(indices[t*3]) b = SubElement(triangle, 'B') b.text = str(indices[t*3+1]) c = SubElement(triangle, 'C') c.text = str(indices[t*3+2]) xml_str = tostring(root) with open('D:\\ctetemptriangle.xml', 'wb') as f: f.write(xml_str) ui.messageBox('Done') except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc())) def GetMatrix(occurrence): ui = None try: app = adsk.core.Application.get() ui = app.userInterface matrix = occurrence.transform while occurrence.assemblyContext: matrix.transformBy(occurrence.assemblyContext.transform) occurrence = occurrence.assemblyContext return matrix except: if ui: ui.messageBox('Get Matrix failed:\n{}'.format(traceback.format_exc()))
