Fusion API Turning programming
retry.ren
retry.ren
There are some recurrent pieces that I have to make often that are always different, but I always follow the same steps for programming. I have saved tons of time just by having default settings and presets, but I am looking to go faster. I tried to use the API to make a script, but I haven't found proper documentation regarding turning programming with the API. There is just one example, and it is for milling.  Is it there some information I am missing? Has anyone else experienced something like this?
Best regards
rohit_maneYV8C9
Hello @retry.ren ,
You can refer this post for reference, As I explained there, you will find that most of the codes are the same as in the Basic milling workflow. Only the parameter names for some values might be different. You just need to look for the correct parameter names and corresponding values. I hope this helps.
