Fusion 360 to UGS Failed to post
kulpio
kulpio
Hi everyone,
I am trying to get UGS Plugin to work with Fusion 360. I did everything I had to do to install the plugin (which is in my F360 plugin library) and followed the instruction on the Post to UGS pop up window.
However, I get the following error (screenshot attached).
Would anyone have an idea on how to get it to work, or what I did wrong?Also attached my "Post to UGS" pop up settings.
My CNC machine is a Shapeoko3 XL
I run on Mac
F360 has the latest update.
kulpio
So I found the issue. It was my path for the UGS which should not include "Macintosh HD" for some reason.
However now I get the following errors in UGS when I run the job:
An error was detected while sending 'T5M6': (error:20) Unsupported or invalid g-code command found in block. Streaming has been paused.
So why is it creating invalid g-code?
Should I insert my tool library into UGS as well so it supports them?
... very confused and not very good at this.
BrianEkins
It's best to ask the developer of the add-in.  No one here has any detailed information about specific add-ins.  This forum is for general questions about the Fusion 360 programming interface, not the add-ins that use it.
Brian Ekins
