Fusion 360 Python API - Correct call to remove components from design tree or timeline
AloneButt
AloneButt
Hello everyone!
I’m working on a Fusion 360 Python script where I need to clear the design at the end of its execution.
I hit a wall when it became necessary to REMOVE the components. I figured out how to DELETE components and SUPPRESS timeline objects; however, I need to keep the earlier history and dependencies after the removal, therefore, those are not an option.
I searched the net, looked through forums, and asked AIs a lot of questions, but could not locate the correct call or a way to do 'Soft delete' through a script.
I’d appreciate any guidance or a working example. Thank you!
BrianEkins
Have you tried creating a RemoveFeature
Brian Ekins
Inventor and Fusion 360 API Expert
Website/Blog: https://EkinsSolutions.com
AloneButt
Thank you!
suikerhub
Hello, I seem to have the same problem. Using the RemoveFeature seems only capable of removing bodies. I can't find a way in the API documentation to remove components however. Is it currently only possible to remove bodies and not components?
