Fusion 360 crashes on filedialog.askopenfile() method call
t_tkacp
Alumni Alumni
t_tkacp
Hi guys!
I have some small issue while I'm try to use OpenFileDilog. Fusion crashes all the time when I try to select file in OpenFileDilog window.
I'm using TK lib. Method -  filedialog.askopenfile()
My Python code looks like this:
root = Tk()
Button(root, text = 'Open', command = OpenFile)
def OpenFile():
    fname = filedialog.askopenfile(filetypes=("JSON files", ".json"))
P.S. This code works fine outside Fusion enviroment.
marshaltu
We had known issue whick Tkinter cannot work well with Fusion in MAC. Though it worked well in Windows. We are pursuing a solution for that.
I would ask if you only got the crash in MAC? If not, it might be different issue. Please provide a runnable test case to us to reproduce the crash.
Marshal
Marshal Tu
Fusion Developer
t_tkacp
Here is some additional info:
OS: Windows 8.1 x64
Fusion: latest version (updated today 07/27/2015)
Steps to reproduce:
1) Unpack attached files to AddIns folder
2) Run Addin in Fusion
3) In opened window click 'Open' button
4) OpenFileDialog will appear. You can navigate through folders, but once you click on any file Fusion will crash.
Pavel.
marshaltu
Thank you for sharing the addin sample. I can reproduce the issue in Win 8. It worked well in Win 7. We will investigate what's the problem.
Marshal
Marshal Tu
Fusion Developer
