Fit-point splines sharing a sketch point
rarora7777
rarora7777
I have a network of interconnected 3D curves. The data is stored in two CSV files: one containing the 3D points and another containing sequences of indices into the set of points specifying curves. I'm able to load this data into Fusion and build spline curves (SketchFittedSpline curves). However, I want a user to be able to move these points interactively, and the splines to react to the user input. Therefore, I try to merge the logically duplicate points obtained via SketchFittedSpline.firPoints. This works sometimes, but fails with a runtime error at other times:
"RuntimeError: 5: Failed to solve. Please try revising dimensions or constraints."
Here's a small reproducible example:
#Author-Rahul Arora
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        product = app.activeProduct
        points = adsk.core.ObjectCollection.create()
        points.add(adsk.core.Point3D.create(-1, 0, 0))
        points.add(adsk.core.Point3D.create( 0, 0, 0))
        points.add(adsk.core.Point3D.create( 1, 0, 0))
        points.add(adsk.core.Point3D.create( 0, 1, 0))
        design = product
        root = design.activeComponent
        sketch = root.sketches.add(root.xYConstructionPlane);
        idx1 = [0, 1, 2]
        idx2 = [1, 3]
        pts1 = adsk.core.ObjectCollection.create()
        for i in idx1 :
            pts1.add(points[i])
        pts2 = adsk.core.ObjectCollection.create()
        for i in idx2 :
            pts2.add(points[i])
        sketch.sketchCurves.sketchFittedSplines.add(pts1)
        spline1 = sketch.sketchCurves.sketchFittedSplines.item(sketch.sketchCurves.sketchFittedSplines.count - 1)
        sketch.sketchCurves.sketchFittedSplines.add(pts2)
        spline2 = sketch.sketchCurves.sketchFittedSplines.item(sketch.sketchCurves.sketchFittedSplines.count - 1)
        pts1 = spline1.fitPoints
        pts2 = spline2.fitPoints
        assert pts1.count == len(idx1)
        assert pts2.count == len(idx2)
        if pts1.item(1) != pts2.item(0) and pts1.item(1).geometry.distanceTo(pts2.item(0).geometry) < 1e-6:
            pts1.item(1).merge(pts2.item(0))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Lines 44-47 are just sanity checks and you can ignore them. Line 48 (the last line before the except statement) is where the error occurs.
What am I doing wrong?
BrianEkins
The most efficient way to approach this is to create a sketch point for each of the coordinates and then use the Sketch point objects as input instead of Point3D objects when creating the spline.
Brian Ekins
rarora7777
Hi Brian! Thanks for your quick response.
Actually, this is what I tried in the first place. But the sketchFittedSplines.add() function seems to create new sketch points. Here's an example:
#Author-Rahul Arora
#Description-
def run(context):
    ui = None
    try:
        design = product
        for i in range(0, points.count) :
            sketch.sketchPoints.add(points.item(i))
        idx1 = [0, 1, 2]
        idx2 = [1, 3]
        for i in idx1 :
            pts1.add(sketch.sketchPoints.item(i))
        for i in idx2 :
            pts2.add(sketch.sketchPoints.item(i))
        ui.messageBox('(before) #SketchPoints: ' + str(sketch.sketchPoints.count))
        ui.messageBox('(after) #SketchPoints: ' + str(sketch.sketchPoints.count))
    except:
        if ui:
 Th number of points increases from 5 (4 of my points + the origin, I guess) to 9.
The same effect can be observed in the UI as well. Create a few sketch points and then try to create a fit spline though them, and you'd see 2 sketch points at each location.
Is there a catch or workaround?
rarora7777
However, I replaced the merge operation in the original code with coincidence constraints and that seems to work well. I tried on a complex example as well and it works well for me. But I'd still be interested to know why the merge operation fails, or if there is a better way to avoid duplicate points.
Here's the code with the coincidence constraints:
#Author-Rahul Arora
#Description-
def run(context):
    ui = None
    try:
        design = product
        idx1 = [0, 1, 2]
        idx2 = [1, 3]
        for i in idx1 :
            pts1.add(points[i])
        for i in idx2 :
            pts2.add(points[i])
            sketch.geometricConstraints.addCoincident(pts1.item(1), pts2.item(0))
    except:
        if ui:
Maybe it'll help someone in the future.
