05:11 AM
- Mute
- Permalink
- Report
Hi, I'm accessing a number of joints, but one is missing from the component's joint list. Perhaps someone will see what I'm doing wrong. Thank you
Using the Python Fusion 360 API, I've managed to find the joint list for the component in my assembly, and can enumerate the joint names, but one joint is missing, Rev6.
(Pdb) root = design.rootComponent
(Pdb) comp1 = root.occurrences.itemByName('_0006_SA02_Default:1').childOccurrences.itemByName('0006_001_MC01-5_Default:1').component
(Pdb) comp1.name
(Pdb) [x.name for x in comp1.joints]
['Rev7', 'Rev10', 'Cyl15']
(Pdb)
Using ui.selectEntity(...), I can select Rev6, verify its name, verify that I have the same parent as with the previous code, and verify that the parent's joints list is missing Rev6.
(Pdb) j1 = ui.selectEntity('Select joint', 'Joints').entity
(Pdb) j1.name
Rev6
(Pdb) j1.parentComponent.name
(Pdb) [x.name for x in j1.parentComponent.joints]
Selecting a different joint associated with the parent shows the same result.
(Pdb) j1.name
Rev7
