findFileByFileID() fails unless Fusion has already 'seen' the file
chris.monachanZWSCF
chris.monachanZWSCF
I'm finding that the first time I call findFileByFileID() with a valid URN it fails. If I then iterate through all the files in code or just in the UI Dataview browse to where the file is, the call then doesn't fail.  Snippet of C++:
auto ptrFile = ptrApplication->data()->findFileById( oFileURNAttribute->value() );
The ID I'm using is in the form : 'urn:adsk.wipprod:dm.lineage:A09KFuSFRWevaFnZKMhA1Q'
Is this expected behaviour? The documentation doesn't say anything about it needing the file to be already discovered before the findFileById() method works. It is very reproducible.
BrianEkins
There's a similar problem that has been fixed in the next release, which should be out later this month.  You should try testing this again when it comes out.  If it's still a problem, please report it here.
Brian Ekins
chris.monachanZWSCF
Excellent. There are always a good number of bugs fixed with each release. Looking forward to it. Thanks.
chris.monachanZWSCF
Just FYI. This still seems to be broken in the latest release. The work-a-round is to browse the files in the DataManager first before trying to open one.
chris.monachanZWSCF
Hi Brian,
Just to say that as well as this not being fixed, I think there has been a regression in the file system. Now my drawing templates aren't found, unless I browse to the area in the cloud file system where they are stored first. Otherwise it just reports an error.
Shall I put this as a separate post on the forum or is it already a bug you're tracking?
