Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Find All T-Splines by text command or python
Hello
I am sure this is an easy question but I searched all day for a solution. I am writing a script to automate some modification on 3D models before CAM.
In design, Some 3d meshes ( with .obj extension)  are imported and converted to "Quad to T-spline". I can do that with this script.
import adsk.core, adsk.fusion, adsk.cam, traceback
import os
ui = None
app = adsk.core.Application.get()
ui  = app.userInterface
def run(context):
    try:
        string = ui.inputBox("Directory","File link")
        ui.messageBox(string[0])
        design = adsk.fusion.Design.cast(app.activeProduct)
        design.designType = adsk.fusion.DesignTypes.ParametricDesignType
        #Import Meshes
        file_list = os.listdir(string[0])
        for obj in file_list:
            file_url = os.path.join(string[0], obj)
            design.rootComponent.meshBodies.add(file_url, adsk.fusion.MeshUnits.MillimeterMeshUnit)
        design.designType = adsk.fusion.DesignTypes.DirectDesignType
        #Change Names of Meshes and Create T-Spline from them
        array = design.rootComponent.meshBodies
        for component in array:
            component.name = ' '.join([str(elem) for elem in component.name.split(' ')[4:]])
            ui.activeSelections.clear()
            ui.activeSelections.add(component)
            #Create T-Spline for each model
            app.executeTextCommand("Commands.Start TSpline2BRepCommand")
            x = app.executeTextCommand("NuCommands.CommitCmd")
            # At this point, I added a screenshot of the browser
            # For now, I need to do these
            # 1) Changing name of T-Spline with component.name
            # 2) Add thicken feature to Mesh with 0.1 mm
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
My problem is that I can not iterate the T-Spline objects. If I can get the T-spline which is created with textcommand above.  I can change its name and add a thichen modification.
Best Regards
kandennti
Hi @Anonymous .
Could you please attach a couple of OBJ files?
The error occurs in an unrelated area and it is difficult to reproduce the situation.
Hi
Thank you for your help.  I attached the sample folder.
1) Exporting zip file to someplace
2) When you run the script, copy- and paste the directory of the folder into the input box.
C:\Users\xxxx\Downloads\xxxx\sample
The script is working on windows system but I think it also works on Linux or Mac because of python libraries.
Best Regards
kandennti
@Anonymous .
I couldn't find a way to access the TSplineBody, so I went into Parametric Design to edit the FormFeatur and converted it.
After that, I think I can add the thickness of the surface.
import os
ui = None
def run(context):
    try:
        # string = ui.inputBox("Directory","File link")
        # ui.messageBox(string[0])
        string  = [r'C:\Temp']
        #Import Meshes
        # design.designType = adsk.fusion.DesignTypes.DirectDesignType
        # Create FormFeature
        root = design.rootComponent
        forms = root.features.formFeatures
        fFeat :adsk.fusion.FormFeature = forms.add()
        tBodies :adsk.fusion.TSplineBodies = fFeat.tSplineBodies
        # FormFeature start edit
        fFeat.startEdit()
        meshBodies = design.rootComponent.meshBodies
        for mBody in meshBodies:
            mBody.name = ' '.join([str(elem) for elem in mBody.name.split(' ')[4:]])
            ui.activeSelections.add(mBody)
            # rename TSplineBody
            tBody :adsk.fusion.TSplineBody = tBodies[-1]
            tBody.name = mBody.name
        # FormFeature finish edit
        fFeat.finishEdit()
    except:
        if ui:
