Feature request - Create Setups
Joshua.mursic
Message 1 of 14
Joshua.mursic
Is it possible to update the API to add just simple setup creation. We are currently restricted to using text commands, which I have found can be very buggy. Even just being able to create a setup and select the workplaces and models would be a huge help to me, and I’m sure many others.
Accepted solutions (3)
Replies (13)
Message 2 of 14
boopathi.sivakumar
Hi @Joshua.mursic
Wait for one more week. We have a surprise for you😊
Boopathi Sivakumar
Principal Technology Consultant
Message 3 of 14
Joshua.mursic
Looking forward to it! Thanks @boopathi.sivakumar
Message 4 of 14
echatzief
Hey @Joshua.mursic
Take a look here:
## bodyCollection refers to an object collection!
occs = rootComp.occurrences
occ = occs[0]
child_component = occ.component
child_bodies = child_component.bRepBodies
in_body = child_bodies[0] # brepBody
cam = adsk.cam.CAM.cast(products.itemByProductType("CAMProductType"))
setup = createSetups(cam, in_body)
def createSetups(cam_, targetBody : adsk.fusion.BRepBody) -> adsk.cam.Setup:
    global bodyCollection
    bodyCollection.add(targetBody)
    existingSetups = cam_._get_setups() # setups
    targetSetup = existingSetups.createInput(adskCam.OperationTypes.MillingOperation) # SetupInput
    newSetup = existingSetups.add(targetSetup) # setup
    newSetup._set_models(bodyCollection)
    bodyCollection.clear()
    return newSetup
Message 5 of 14
Joshua.mursic
That's awesome! Thanks @echatzief, where did you find these functions in the documentation? Are there more of these? I would also like to be able to set the work coordinate system. Thanks for sharing your knowledge.
cam_._get_setups()
Message 6 of 14
echatzief
You are definitely able to change wcs.
Message 7 of 14
kandennti
@echatzief .
I am amazed. You have created a setup without having to switch to a manufacturing workspace.
Message 8 of 14
Joshua.mursic
How would I do this? Where did you find the _set_models() and the _get_setups() functions? I do not see them in the documentation.
Message 9 of 14
echatzief
Hey @kandennti,
I am pleased to amaze you.
* I have already switched to manufacturing😛
Message 10 of 14
kandennti
@Joshua.mursic .
It is not documented in the documentation.
The easiest way to check is to stop at a breakpoint and check the variable.
The rest you will have to guess and try.
Message 11 of 14
Joshua.mursic
Is my surprise ready?! @boopathi.sivakumar
Message 12 of 14
anaschat22
Hi @echatzief , can I have some tips on using thos functions?
Thank you.
Message 13 of 14
boopathi.sivakumar
There you go
with the April release now you have more access to the cam api
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-36B1FFB5-5291-4532-8F11-90E912769B34
Boopathi Sivakumar
Message 14 of 14
Joshua.mursic
Very exciting! thank you
