Failed to post in addsin
tomas.wilhelmsson
Message 1 of 9
tomas.wilhelmsson
Hmm noticed after the last update that my addin for post processing started to fail .. CAM Object -> postProcess fails each time 😕
Adding a small example program .. incase ive done something wrong but this one also fails on me 😕
Best regards
/ Tomas
Replies (8)
Message 2 of 9
zhongyang.chenK3XZJ
I tried on my machine running the attached add-in.
Unfortunately, I didn't encounter the failure you mentioned.
Perhaps it was because my design is too simple.
It would be appreciated if you could attach or share the design you're using to help reproduce the issue.
Zhongyang Chen
Fusion 360 API Developer
Message 3 of 9
tomas.wilhelmsson
Hmm strange, the addin fails on all my designs. Will try and reinstall fusion and see if the issue resolvs itself 😃
Thanks / Tomas
Message 4 of 9
tomas.wilhelmsson
Nope did not work, is there any way to extract the reason for failiure somehow ? 😕 adding the file im trying to post also
Thanks / Tomas
Message 5 of 9
tomas.wilhelmsson
now ive even tried a clean install of windows and fusion 360 .. still getting failed to post with my script 😕
Why isnt there a CAM::getLastError or something that works with the CAM objects ? Application::getLastError doesnt seem to work and i cant find any log files 😕
Message 6 of 9
tomas.wilhelmsson
Tried the direct example from this page: http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-BF31EB56-B612-44C8-8F07-0C183036C803
and that also fails when posting ... with new install of windows and new fusion 360 install...
tried both the python and the c++ version .. none of them post any files 😕
the internal post process in fusion seems to work fine
Message 7 of 9
I have an add-in that posts to Universal GCode Sender that is failing as is the add-in I am developing. No error, no file appears.
Where does on file a bug report?
/Daryl
Message 8 of 9
tomas.wilhelmsson
Hey, i accidentaly double posted this and this thread someone is answering in: https://forums.autodesk.com/t5/fusion-360-api-and-scripts/cam-postprocessor-not-working/td-p/7474250
Message 9 of 9
Thanks for alerting me to the other thread, Thomas!
