face.boundingBox viewed from the direction of a known adsk.core.Vector3D
maurizio_manzi
maurizio_manzi
face.boundingBox provides a bounding box that originates from the global coordinate system and is aligned with the global coordinate system. Is there a way to obtain a bounding box that originates from the global coordinate system but is viewed from the direction of a known adsk.core.Vector3D?
Best regards
Maurizio
kandennti
Hi @maurizio_manzi -San.
BoundingBox3D relies on the orientation of the global coordinate system.
The size in any vector direction can be obtained with the MeasureManager.getOrientedBoundingBox method, but it will be OrientedBoundingBox3D, not BoundingBox3D.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-DF2F5C84-57C7-4F61-BA05-D2978FFF2724
The following sample outputs the size of the first face of the first body of the root component in the screen direction.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        root: fusion.Component = des.rootComponent
        body: fusion.BRepBody = root.bRepBodies[0]
        face: fusion.BRepFace = body.faces[0]
        bBox: core.BoundingBox3D = face.boundingBox
        # Vector acquisition from eye direction.
        camera: core.Camera = app.activeViewport.camera
        vecLength: core.Vector3D = camera.eye.vectorTo(
            camera.target
        vecWidth: core.Vector3D = vecLength.crossProduct(
            camera.upVector
        # OrientedBoundingBox
        measMgr: core.MeasureManager = app.measureManager
        orientedBBox: core.OrientedBoundingBox3D = measMgr.getOrientedBoundingBox(
            face,
            vecLength,
            vecWidth,
        # dump
        app.log("*********")
        app.log(f"CenterPoint:{orientedBBox.centerPoint.asArray()}")
        app.log(f"LengthDirection:{orientedBBox.lengthDirection.asArray()}")
        app.log(f"Length:{orientedBBox.length}")
        app.log(f"WidthDirection:{orientedBBox.widthDirection.asArray()}")
        app.log(f"Width:{orientedBBox.width}")
        app.log(f"HeightDirection:{orientedBBox.heightDirection.asArray()}")
        app.log(f"Height:{orientedBBox.height}")
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
maurizio_manzi
Thank you very much. This is really helpful.
The Vector3D is acquired from the camera view:
Is there a possibility to use an existing adsk.core.Vector3D variable instead of the camera view? Maybe with also a 3D-Line for the length direction?
I also noticed that even when I use the camera, only the values for "CenterPoint" are correct. All other values are only displayed as fractions of the actual length.
For example, for a length or width of 3.5 cm, only 0.15 cm is shown.
Best regards
Maurizio
kandennti
I have not checked because I am busy, but I forgot to make vecLength a unit vector and that may be the reason.
            camera.target
        vecLength.normalize()
maurizio_manzi
thank you very much.
I add:
vecWidth.normalize()
but if I use simply vectors as vecLength = adsk.core.Vector3D.create(1,0,0) and vecWidth = adsk.core.Vector3D.create(0,1,0)
it works fine. But if I use the camera.eye values for the vectors, the values of the orientated bounding box are all very wrong.
Best regards
Maurizio
kandennti
Fixed to add a block for easier checking.
import traceback
def run(context):
    try:
            camera.target
            camera.upVector
            face,
            vecLength,
            vecWidth,
        # dump
        DumpBoundingBox(orientedBBox)
        ui.activeSelections.clear()
        ui.activeSelections.add(face)
    except:
        if ui:
def DumpBoundingBox(bBox: core.OrientedBoundingBox3D):
    tmpMgr: fusion.TemporaryBRepManager = fusion.TemporaryBRepManager.get()
    tmpBody: fusion.BRepBody = tmpMgr.createBox(bBox)
    baseFeat: fusion.BaseFeature = None
    if des.designType == fusion.DesignTypes.ParametricDesignType:
        baseFeat = root.features.baseFeatures.add()
    bodies: fusion.BRepBodies = root.bRepBodies
    resBody: fusion.BRepBody = None
    if baseFeat:
        baseFeat.startEdit()
        try:
            bodies.add(tmpBody, baseFeat)
        except:
            pass
        finally:
            baseFeat.finishEdit()
            resBody = baseFeat.bodies[0]
    else:
        resBody = bodies.add(tmpBody)
    resBody.opacity = 0.5
It is possible that I misunderstood what you are asking for as well, but the sample script works like this.
maurizio_manzi
I made a mistake. It works.
Best regards
Maurizio
