F360 debugging doesn't work with latest VSC python version
pludikar
Message 1 of 27
pludikar
Just so everyone knows - F360 debugging doesn't work with the last VSC python update (2020.10.332292344).  You need to revert back to v2020.9.114305 for F360 to open up VSC and for debugging to work again.
Peter
I'm not an expert, but I know enough to be very, very dangerous.
Life long R&D Engineer (retired after 30+ years in Military Communications, Aerospace Robotics and Transport Automation).
Replies (26)
Message 21 of 27
MichaelT_123
Hi Mr BradBylls,
Look at some messages from F360 update process. They might contain some clue ...????
Remove file C:\Users\#######\AppData\Local\Autodesk\Autodesk Fusion 360\#######\GraphicsCardInfo.xml
File C:\Users\#######\AppData\Local\Autodesk\Autodesk Fusion 360\#######\session.dat can't be cleaned with property isValid:True isFile:True CleanFlag:ForceAll
Remove file C:\Users\#######\AppData\Local\Autodesk\Autodesk Fusion 360\#######\InUseByCollaboratorCache.xml
Remove file C:\Users\#######\AppData\Local\Autodesk\Autodesk Fusion 360\#######\MRU.xml
Remove file C:\Users\#######\AppData\Local\Autodesk\Autodesk Fusion 360\#######\SavedNotifications.json
File C:\Users\#######\AppData\Local\Autodesk\Autodesk Fusion 360\#######\OfflineCache.xml can't be cleaned with property isValid:True isFile:True CleanFlag:ForceAll
File C:\Users\#######\AppData\Local\Autodesk\Autodesk Fusion 360\#######\_analytic-counters.json can't be cleaned with property isValid:True isFile:True CleanFlag:ForceAll
File C:\Users\#######\AppData\Local\Autodesk\Autodesk Fusion 360\#######\NsCloudBrowserCache.dat can't be cleaned with property isValid:True isFile:True CleanFlag:ForceAll
File C:\Users\#######\AppData\Local\Autodesk\Autodesk Fusion 360\#######\flags.json can't be cleaned with property isValid:True isFile:True CleanFlag:ForceAll
File C:\Users\#######\AppData\Local\Autodesk\Autodesk Fusion 360\UnknownUser can't be cleaned with property isValid:True isFile:False CleanFlag:ForceAll
File C:\Users\#######\AppData\Local\Autodesk\Autodesk Fusion 360\#######\logs can't be cleaned with property isValid:True isFile:False CleanFlag:ForceAll
Remove folder C:\Users\#######\AppData\Local\Autodesk\Neutron Platform\Filelock
Remove folder C:\Users\#######\AppData\Local\Autodesk\Neutron Platform\#######
Remove file C:\Users\#######\AppData\Local\Autodesk\Neutron Platform\OfflineCache.xml
Remove file C:\Users\#######\AppData\Local\Autodesk\Web Services\Event.xml
Remove file C:\Users\#######\AppData\Local\Autodesk\Web Services\EventTrigger.tmp
File C:\Users\#######\AppData\Roaming\Autodesk\Autodesk Fusion 360\CEROption.xml can't be cleaned with property isValid:True isFile:True CleanFlag:ForceAll
File C:\Users\#######\AppData\Roaming\Autodesk\Autodesk Fusion 360\#######\CEROption.xml can't be cleaned with property isValid:True isFile:True CleanFlag:ForceAll
File C:\Users\#######\AppData\Roaming\Autodesk\Autodesk Fusion 360\#######\JSLoadedScriptsinfo can't be cleaned with property isValid:True isFile:True CleanFlag:ForceAll
File C:\Users\#######\AppData\Roaming\Autodesk\Autodesk Fusion 360\#######\PythonAutorunModuleinfo can't be cleaned with property isValid:True isFile:True CleanFlag:ForceAll
File C:\Users\#######\AppData\Roaming\Autodesk\Autodesk Fusion 360\Fusion360_<build-number>_addins_to_load.xml can't be cleaned with property isValid:True isFile:True CleanFlag:ForceAll
Remove folder C:\Users\#######\AppData\Roaming\Autodesk\Autodesk Fusion 360\Fabrication
File C:\Users\#######\AppData\Roaming\Autodesk\Autodesk Fusion 360\CPP can't be cleaned with property isValid:True isFile:False CleanFlag:ForceAll
File C:\Users\#######\AppData\Roaming\Autodesk\Autodesk Fusion 360\Python can't be cleaned with property isValid:True isFile:False CleanFlag:ForceAll
File C:\Users\#######\AppData\Roaming\Autodesk\Autodesk Fusion 360\version.txt can't be cleaned with property isValid:True isFile:False CleanFlag:ForceAll
Remove folder C:\Users\#######\AppData\Roaming\Autodesk\Autodesk Fusion 360\Options
Remove folder C:\Users\#######\AppData\Roaming\Autodesk\Autodesk Fusion 360\#######\Options
File C:\Users\#######\AppData\Local\Autodesk\Production can't be cleaned with property isValid:True isFile:False CleanFlag:ForceAll
File C:\Users\#######\AppData\Local\Autodesk\Web Services can't be cleaned with property isValid:True isFile:False CleanFlag:ForceAll
File C:\Users\#######\AppData\Local\Autodesk\Autodesk Fusion 360\AcCore can't be cleaned with property isValid:True isFile:False CleanFlag:ForceAll
File C:\Users\#######\AppData\Local\Autodesk\Fusion Documentation\AcCore can't be cleaned with property isValid:True isFile:False CleanFlag:ForceAll
Remove folder C:\Users\#######\AppData\Local\Temp\Autodesk\BrowserCache
Failed to remove file C:\Users\#######\AppData\Local\Temp\Autodesk\BrowserCache\2.0.14567\Visited Links because of [WinError 32] The process cannot access the file because it is being used by another process: 'C:\\Users\\#######\\AppData\\Local\\Temp\\Autodesk\\BrowserCache\\2.0.14567\\Visited Links'
Failed to remove file C:\Users\#######\AppData\Local\Temp\Autodesk\BrowserCache\2.0.14567 because of error [WinError 145] The directory is not empty: 'C:\\Users\\#######\\AppData\\Local\\Temp\\Autodesk\\BrowserCache\\2.0.14567'
Failed to remove file C:\Users\#######\AppData\Local\Temp\Autodesk\BrowserCache because of error [WinError 145] The directory is not empty: 'C:\\Users\\#######\\AppData\\Local\\Temp\\Autodesk\\BrowserCache'
Remove folder C:\Users\#######\Autodesk\BrowserCache
Remove folder C:\WINDOWS\Autodesk\BrowserCache
Failed to remove file C:\Users\#######\AppData\Local\Temp\Autodesk because of error [WinError 145] The directory is not empty: 'C:\\Users\\#######\\AppData\\Local\\Temp\\Autodesk'
Remove folder C:\Users\#######\AppData\Local\Temp\Proteinrun
Remove folder C:\Users\#######\AppData\Local\Temp\ProtoLabs
Remove folder C:\Users\#######\AppData\Local\Temp\Neutron
Failed to remove file C:\Users\#######\AppData\Local\Temp\Neutron\Generated\Version1\Neutron\UI\Base\Resources\ActionMenu\icons\spinner\normal\0x0-normal.png because of [WinError 32] The process cannot access the file because it is being used by another process: 'C:\\Users\\#######\\AppData\\Local\\Temp\\Neutron\\Generated\\Version1\\Neutron\\UI\\Base\\Resources\\ActionMenu\\icons\\spinner\\normal\\0x0-normal.png'
Failed to remove file C:\Users\#######\AppData\Local\Temp\Neutron\Generated\Version1\Neutron\UI\Base\Resources\ActionMenu\icons\spinner\normal because of error [WinError 145] The directory is not empty: 'C:\\Users\\#######\\AppData\\Local\\Temp\\Neutron\\Generated\\Version1\\Neutron\\UI\\Base\\Resources\\ActionMenu\\icons\\spinner\\normal'
Failed to remove file C:\Users\#######\AppData\Local\Temp\Neutron\Generated\Version1\Neutron\UI\Base\Resources\ActionMenu\icons\spinner because of error [WinError 145] The directory is not empty: 'C:\\Users\\#######\\AppData\\Local\\Temp\\Neutron\\Generated\\Version1\\Neutron\\UI\\Base\\Resources\\ActionMenu\\icons\\spinner'
Failed to remove file C:\Users\#######\AppData\Local\Temp\Neutron\Generated\Version1\Neutron\UI\Base\Resources\ActionMenu\icons because of error [WinError 145] The directory is not empty: 'C:\\Users\\#######\\AppData\\Local\\Temp\\Neutron\\Generated\\Version1\\Neutron\\UI\\Base\\Resources\\ActionMenu\\icons'
Failed to remove file C:\Users\#######\AppData\Local\Temp\Neutron\Generated\Version1\Neutron\UI\Base\Resources\ActionMenu because of error [WinError 145] The directory is not empty: 'C:\\Users\\#######\\AppData\\Local\\Temp\\Neutron\\Generated\\Version1\\Neutron\\UI\\Base\\Resources\\ActionMenu'
Failed to remove file C:\Users\#######\AppData\Local\Temp\Neutron\Generated\Version1\Neutron\UI\Base\Resources because of error [WinError 145] The directory is not empty: 'C:\\Users\\#######\\AppData\\Local\\Temp\\Neutron\\Generated\\Version1\\Neutron\\UI\\Base\\Resources'
Failed to remove file C:\Users\#######\AppData\Local\Temp\Neutron\Generated\Version1\Neutron\UI\Base because of error [WinError 145] The directory is not empty: 'C:\\Users\\#######\\AppData\\Local\\Temp\\Neutron\\Generated\\Version1\\Neutron\\UI\\Base'
Failed to remove file C:\Users\#######\AppData\Local\Temp\Neutron\Generated\Version1\Neutron\UI because of error [WinError 145] The directory is not empty: 'C:\\Users\\#######\\AppData\\Local\\Temp\\Neutron\\Generated\\Version1\\Neutron\\UI'
Failed to remove file C:\Users\#######\AppData\Local\Temp\Neutron\Generated\Version1\Neutron because of error [WinError 145] The directory is not empty: 'C:\\Users\\#######\\AppData\\Local\\Temp\\Neutron\\Generated\\Version1\\Neutron'
Failed to remove file C:\Users\#######\AppData\Local\Temp\Neutron\Generated\Version1 because of error [WinError 145] The directory is not empty: 'C:\\Users\\#######\\AppData\\Local\\Temp\\Neutron\\Generated\\Version1'
Failed to remove file C:\Users\#######\AppData\Local\Temp\Neutron\Generated because of error [WinError 145] The directory is not empty: 'C:\\Users\\#######\\AppData\\Local\\Temp\\Neutron\\Generated'
Failed to remove file C:\Users\#######\AppData\Local\Temp\Neutron because of error [WinError 145] The directory is not empty: 'C:\\Users\\#######\\AppData\\Local\\Temp\\Neutron'
Remove folder C:\Users\#######\AppData\Local\Temp\FusionStreamer
File C:\Users\#######\AppData\Roaming\Autodesk\MC3 can't be cleaned with property isValid:True isFile:False CleanFlag:ForceAll
File C:\Users\#######\AppData\Roaming\Autodesk\Neutron Platform can't be cleaned with property isValid:True isFile:False CleanFlag:ForceAll
File C:\Users\#######\AppData\Roaming\Autodesk\NINVFUS can't be cleaned with property isValid:True isFile:False CleanFlag:ForceAll
File C:\Users\#######\AppData\Roaming\Autodesk\Synergy can't be cleaned with property isValid:True isFile:False CleanFlag:ForceAll
File C:\Users\#######\AppData\Roaming\Autodesk\Neutron can't be cleaned with property isValid:True isFile:False CleanFlag:ForceAll
Regards
MichaelT
MichaelT
Message 22 of 27
brad.bylls
I deleted the ms.python.python files and then I try to debug a script.
It opens VSC and then this.
And no debugging happens.
Brad Bylls
Message 23 of 27
pludikar
@rushikesh.kadam
Hi @MichaelT_123
I just want to check that you got these error messages from your own computer?  I saw exactly the same log messages (appears to be 100% identical) when I updated my F360 to the latest version.  I reported the problem to AD (via insider problem reporting), but it wasn't given any attention, I suspect because F360 still works, and not enough people have reported the issue!
I strongly suspect that there's a cache file that isn't being deleted, and it's probably associated with one of the files listed in the error log - there are just too many to go through one by one.
Peter
Message 24 of 27
brad.bylls
@MichaelT_123 where do you find these messages?
Brad
Brad Bylls
Message 25 of 27
pludikar
Hi @brad.bylls
Unfortunately they don't make it obvious.  In my case I just happened to have VSC open when I initiated an upgrade - and, I got a slew of log messages on the VSC terminal.  I had the presence of mind to copy and paste the logs to notepad.  If I hadn't seen the messages I don't think I would had ever known that there was an issue.  There wasn't a failure message or any other indication to show that something didn't go right.
I suspect that these messages indicate that some files are not actually upgraded, and so it's possible that there's a mix of supporting file versions (which can't be good).  I can't seem to get AD to react- they're not interested unless there's a throng of voices or something has obviously failed.
Peter
Message 26 of 27
MichaelT_123
Hi Mr BradBylls, Pludicar,
As I understand, VSCode conducts debugging process using JavaScript node.js, which takes configuration params launch.json . The detailed semantics are available on VSCode web pages.
Regarding your problem, pay attention to the debug port configuration. Do you have some network ports blocking software, firewalls, software utilizing standard VSCode debug port for a different purposes, malicious viruses, specific network hardware,... etc.?
Where I got the messages from?  Well, I have brought them from .... debug panel of VSCode itself, although I think they could be found in the local log files also.
Regards
MichaelT
MichaelT
Message 27 of 27
brad.bylls
@MichaelT_123 @JeromeBriot @pludikar
I don't understand all that port stuff.
What I did find find, is if I start a debug in F360 which then opens VSC and nothing happens, I click F5 (which starts debugging) and then it will debug as usual.
Brad
Brad Bylls
