Extrude with start offset plane
brad.bylls
brad.bylls
I am using the 'Bolt' example to create a cap screw.
All is going well until I want to cut the hex in the head.
No problem cutting the hex, but I want it to start with an offset from the plane.
My code so far to cut the hex:
prof = sketch.profiles[0]
        extInput = extrudes.createInput(prof, adsk.fusion.FeatureOperations.CutFeatureOperation)
        distance = adsk.core.ValueInput.createByReal(self.headHeight*-1)
        extInput.setDistanceExtent(False, distance)
        headExt = extrudes.add(extInput)
What I can't figure out is how to offset the start plane to distance*.4 and finish at distance
Any help is appreciated.
Thank you.
Brad Bylls
goyals
There is API method available to offset the plane. Please take a look at http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-a4f85da0-15bd-480e-af9a-d9355ebbad08
Shyam Goyal
Sr. Software Dev. Manager
BrianEkins
This should be possible by create an extrusion with two extents and the first extent is defined by an
OffsetStartDefinition object.  I tried this and it's not working correctly.  Autodesk has logged a bug and hopefully it will be addressed soon.
Brian Ekins
brad.bylls
Thanks for the help.
Brad Bylls
brad.bylls
Thanks Brian.
Brad Bylls
