Extrude Surfaces same plane (not on the same plane error)
sebmorales
sebmorales
Hola!
I am having some problems with a script that will slice a part with a plane, then project the intersection of the part with the plane on a sketch. Finally, it will extrude those profiles (as surfaces).
The script works fine for most geometries but occasionally crashes giving the error: "input curves are not on the same plane". I don't understand how this is happening since the input curves were created by the plane to begin with.
Any ideas? Is this a bug?
I am attaching a sample file where this problem occurs as well as the script where this occurs (it is attached as txt because it wouldn't let me upload a .py file).
Thanks!
Sebastian
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback
app = adsk.core.Application.get()
if app:
    ui = app.userInterface
def run(context):
    try:
        activeDoc = adsk.core.Application.get().activeDocument
        design = activeDoc.design
        rootComp = design.rootComponent
        rootComp.occurrences.addNewComponent (adsk.core.Matrix3D.create()).component.name=("extrusions")
        modelMinZ=rootComp.boundingBox.minPoint.z+0.002
        planes=rootComp.constructionPlanes
        planeInOff=planes.createInput()
        planeInOff.setByOffset(rootComp.xYConstructionPlane,adsk.core.ValueInput.createByReal(modelMinZ))
        planeMin=planes.add(planeInOff)
        planeMin.isLightBulbOn=False
        sketches= rootComp.sketches
        sketch = sketches.add(planeMin)
        body = rootComp.bRepBodies.item(0)
        sketch.projectCutEdges(body)
        extrudesComp = rootComp.occurrences.itemByName("extrusions:1").component
        extrudes = extrudesComp.features.extrudeFeatures
        distance = adsk.core.ValueInput.createByReal(2)
        curves=sketch.sketchCurves.item(0)
        profileCollection = adsk.core.ObjectCollection.create()
        profileCollection.add(rootComp.createOpenProfile(curves))
        extrudeInput = extrudes.createInput(profileCollection, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        extrudeInput.isSolid = False
        extrudeInput.setDistanceExtent(False, distance)
        extrude = extrudes.add(extrudeInput)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Error Message
ekinsb
There does appear to be a problem in the API that I'll log a bug for.
However, there's another approach that is better and works.  If you remove the crossed out lines below and add the code in red, it works.
        prof = sketch.profiles.item(0)
        extrudeInput = extrudes.createInput(prof, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
Brian Ekins
Mod the Machine blog
sebmorales
Awesome! This works pretty well. Do you know how this could work in case the profile was open? Lets say the input body is not solid but a surface?
Thanks!
ekinsb
I'm not finding a way that works with an open profile.  We're in the process of changing the concept of a Profile so that Profiles should only be used for closed 2D sections.  Paths should be used for open and/or 3D sets of connected curves.  With this new concept, you should be creating a Path instead of a Profile, but I tested that too and it also has a problem.  I've logged both of the issues so we can get them fixed.  The only thing I found that worked is if I just extrude one curve at a time.
Brian Ekins
sebmorales
That sounds ideal, and thoughts for when this might be released? I just want to know if I should try to fix it now another way or if I should just wait.
Thank you for taking a dive at it though!
Sebastian
