Extension InViewerSearch
               We want to add our viewer extension: Autodesk.InViewerSearch
I have done the steps indicated in the link:
https://developer.autodesk.com/en/docs/viewer/v2/tutorials/in-viewer-search-ext/
The declaration of the variable config3d:
var config3d = {
    extensions: ['MyBotonesExtension', 'Autodesk.InViewerSearch']
config3d.inViewerSearchConfig = {
            searchDefaultText: "",
            uiEnabled: true,
            clientId: 'adsk.viewer.defaultClientId',
            sessionId: 'adsk.viewer.defaultSessionId',
        relatedItemsTab:{
            enabled: true,  //if false we hide the tab
            displayName: 'This Item',
            pageSize: 20
        loadedModelTab: {
            displayName: 'This View',
            pageSize: 50
viewerApp.registerViewer(viewerApp.k3D, Autodesk.Viewing.Private.GuiViewer3D, config3d);
In my index.html:
    <script src="https://developer.api.autodesk.com/viewingservice/v1/viewers/three.min.js"></script>
    <script src="scripts/Extension-InViewerSearch.js"></script>
    <script src="https://developer.api.autodesk.com/viewingservice/v1/viewers/viewer3D.min.js?v=2.11.*"></script>
Extension-InViewerSearch.js->
https://autodeskviewer.com/viewers-dev/latest/docs/extensions_InviewerSearch_InViewerSearchExtension...
ERROR:
ypeError: n[m] is undefined
i.initSharedPropertyDatabase()    viewer3D.min.js:38
i.initCurrentPropertyDatabase()   viewer3D.min.js:38
i.getCurrentGeometryAttributes()  viewer3D.min.js:38
f/h.initializeAllAttributes()     viewer3D.min.js:38
j.InViewerSearchThisView.prototype.initialize()  viewer3D.min.js:38
a() viewer3D.min.js:36
h/p() viewer3D.min.js:36
f/<()
I change viewer3d.min.js by viewer3d.js
ERROR IN viewer3D.js:
ypeError: geometriesFlat[current] is undefined
proto.initSharedPropertyDatabase() viewer3D.js:89706
proto.initCurrentPropertyDatabase() viewer3D.js:89724
proto.getCurrentGeometryAttributes() viewer3D.js:89778
Controller/ctrl.initializeAllAttributes() viewer3D.js:88945
viewerSearchNameSpace.InViewerSearchThisView.prototype.initialize() viewer3D.js:88260
initializeSearchTabs() viewer3D.js:85412
initialize/onGetGeometriesDone() viewer3D.js:85603
getGeometries/<()
I made another extension running development differently, when the geometry is loaded and ... the result has been the same ... same error:
viewer.addEventListener(Autodesk.Viewing.GEOMETRY_LOADED_EVENT,
                    function (event) {
                        var options = {
                            uiEnabled: true,
                            thresholdSearchMaxNodes: 50000,
                            loadedModelTab: {
                                enabled: true,
                                pageSize: 50
                            relatedItemsTab: {
                                enabled: true,
                                pageSize: 20
                        viewer.loadExtension("Autodesk.InViewerSearch", options);……..
 In the display only shows the magnifying glass icon.
I hope to hear from somebody soon...
<br class="Apple-interchange-newline"><div id="inner-editor"></div>
Thank you so much
ekinsb
This forum is for questions about Fusion 360. For Forge questions they're using Stackoverflow and the Forge experts are watching there for questions.  Can you please re-post your question on Stackoverflow?
Brian Ekins
Mod the Machine blog
