Extend Feature: RuntimeError: 5 : Some input argument is invalid.
bradandersonjr
bradandersonjr
Hey!
I created a Python add-in several years ago called `Guitar Engine`.  I haven't made many changes to it in over 3 years.  As of a few updates ago the script no longer properly functions and I can't figure out it.
I receive this error now:
Failed:
Traceback (most recent call last):
  File "C:/Users/brad/AppData/Roaming/Autodesk/Autodesk Fusion 360/API/AddIns/Guitar Engine [Beta]/Guitar Engine [Beta].py", line 1512, in buildFretboard
    extendFeature1 = extendFeatures.add(extendFeatureInput1)
  File "C:\Users/brad/AppData/Local/Autodesk/webdeploy/production/fd081b4c15f2fc37998034adb20de16163fc298f/Api/Python/packages\adsk\fusion.py", line 20197, in add
    return _fusion.ExtendFeatures_add(self, input)
Here's the tidbit of code this is referencing:
# Get the body created by the stitch
        face = stitch.bodies.item(0)
        if createFilletRadius.value:
            topFace = face.faces.item(6)
        else:
            topFace = face.faces.item(4)
        # Create input entities for offset feature
        inputEntities = adsk.core.ObjectCollection.create()
        inputEntities.add(topFace)
        # Create an input for offset feature
        offsetFeature = fretboardComp.features.offsetFeatures
        offsetInput = offsetFeature.createInput(inputEntities, adsk.core.ValueInput.createByReal(-tangDepth),
                                                 adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        #Get the surface body.
        extrudeFeature = offsetFeature.add(offsetInput)
        extrudeFeature.name = 'Offset: Fret Projections'
        offSurf = extrudeFeature.bodies.item(0)
        offSurf.name = 'Reference for fret cuts'
        offSurf.isVisible = False
        #Get an edge from surface, and add it to object collection.
        extend = offSurf.edges
        ext1 = extend.item(0)
        ext2 = extend.item(1)
        ext3 = extend.item(2)
        ext4 = extend.item(3)
        inputEdges = adsk.core.ObjectCollection.create()
        inputEdges.add(ext1)
        inputEdges.add(ext2)
        inputEdges.add(ext3)
        inputEdges.add(ext4)
        #Define a distance to extend.
        distance = adsk.core.ValueInput.createByString('0.5 in')
        #Create an extend input to be able to define the input needed for an extend.
        extendFeatures = fretboardComp.features.extendFeatures
        extendFeatureInput1 = extendFeatures.createInput(inputEdges, distance, adsk.fusion.SurfaceExtendTypes.NaturalSurfaceExtendType)
        #Create an extend feature.
        extendFeature1.name = 'Extend: Fret Projections'
Line 37 is Line 1512 in my script. `extendFeature1 = extendFeatures.add(extendFeatureInput1)`
I've tried to trace backward to see why all of a sudden this creates the error but I can't figure it out.
The code in its entirety is here >> https://github.com/bradandersonjr/GuitarEngine/blob/master/Guitar%20Engine%20%5BBeta%5D.py
I know it's not pretty and needs to eventually be overhauled.
I appreciate any guidance or help offered!
Thank you!
Brad Anderson Jr
Fusion 360 Hobbyist
Fusion 360 Luthiers Facebook Group
BrianEkins
I'm able to reproduce the problem. I'm sure nothing has changed in the API, and I suspect something has changed in the Extend Feature command. When I test the command, I cannot select more than one edge unless they're tangentially connected, and I have the option set to use tangent edges. I don't think it behaved like that before. I'll check with someone at Autodesk to see if there is a behavior change and if it's intentional.
Brian Ekins
bradandersonjr
Hey Brian!
I really do appreciate it, thanks!
Brad Anderson Jr
Fusion 360 Hobbyist
BrianEkins
I tested this some more and now realize I didn't fully understand how to use the command. What I thought was a problem is OK. However, it's possible that some behavior did change and is causing your program to break. Attached is a modified version of your program that gets past the problem you were having. There is some behavior that I don't fully understand and could be a bug.
The initial problem is that the Offset feature returned two bodies, and you were trying to extend the wrong one. I changed the code to get the offset face differently. Also, when offsetting, you were offsetting the first four edges of the body. I changed it to offset all edges so it extends the face all around.
It then runs into a problem when working with a sketch where it's trying to use an index for a line that doesn't exist. I didn't go any further than this because I think this is a logic problem in the code, and I don't understand the workflow.
Brian Ekins
