Expression for different stepdown depending on tool type
sean.gorman
sean.gorman
I am looking for a way to create an expression to drive the stepover of a toolpath depending on the tool type (i.e. using contour with a ball mill as opposed to a square end mill). This is for using toolpaths such as contour with different tool types.
for example:
if tool_type - ball mill, stepover = 0.1
else tool_diameter*0.25
Any help would be appreciated.
kandennti
Hi @sean.gorman .
When I looked for it, the IF statement of expression looks like this.
<Evaluation expression> ? <Return_true> : <Return_false>
In this case.
tool_type == 'ball end mill' ? 0.1 : tool_diameter*0.25
I attached the file, please change the tool and try.
This link may be useful.
https://forums.autodesk.com/t5/fusion-360-manufacture/parameter-names-for-expressions/m-p/5956915#U5...
https://forums.autodesk.com/t5/fusion-360-manufacture/community-resource-expressions-list/td-p/72289...
https://forums.autodesk.com/t5/hsm-support-forum/if-then-expressions-for-stepdown/td-p/6088656
