Exporting area of selected faces from a body
j4n.vokurka
j4n.vokurka
Hey,
I need to export the total area of faces I select from a body to .csv/.txt. I should also be able to change the color of selected faces to highlight them. I've spent some time reading through forums and watching tutorials. Although I mostly found out which objects to use for this task, I'm new to API and have problems scripting it to work properly.  I've managed to put together only few parts of the code, not any solid basis on which to build. I would be greatful if anybody would sent me something that would help me.
I use this logic:
Select face(s) from random body - add them and the area value to an array - let the user select color for the array - calculate the total area of these faces - export it
Things I tried to use:
BRepBodies, BRepFaces - Appearance, ColorProperty -  UserInterface.activeSelectionChanged Event - UserParameters.add Method - areaProperties
Thanks in advance for any help
kandennti
Hi @j4n.vokurka .
I did not understand what you meant about array and color.
The following sample displays the area of several selected surfaces and exports them to a file.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
_app: adsk.core.Application = None
_ui: adsk.core.UserInterface = None
_handlers = []
_facesIpt: adsk.core.SelectionCommandInput = None
_infoIpt: adsk.core.TextBoxCommandInput = None
DEBUG = False
class MyCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: adsk.core.CommandCreatedEventArgs):
        dumpMsg(args.firingEvent.name)
        try:
            global _handlers
            cmd: adsk.core.Command = adsk.core.Command.cast(args.command)
            inputs: adsk.core.CommandInputs = cmd.commandInputs
            # inputs
            global _facesIpt
            _facesIpt = inputs.addSelectionInput(
                '_facesIptId',
                'faces',
                'select faces'
            _facesIpt.setSelectionLimits(0)
            _facesIpt.addSelectionFilter(adsk.core.SelectionCommandInput.Faces)
            global _infoIpt
            _infoIpt = inputs.addTextBoxCommandInput(
                '_infoIptId',
                'total area',
                1,
                True
            # event
            onDestroy = MyCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            onExecute = MyExecuteHandler()
            cmd.execute.add(onExecute)
            _handlers.append(onExecute)
            onInputChanged = MyInputChangedHandler()
            cmd.inputChanged.add(onInputChanged)
            _handlers.append(onInputChanged)
            onValidateInputs = MyValidateInputsHandler()
            cmd.validateInputs.add(onValidateInputs)
            _handlers.append(onValidateInputs)
        except:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class MyValidateInputsHandler(adsk.core.ValidateInputsEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: adsk.core.ValidateInputsEventArgs):
        global _facesIpt
        if _facesIpt.selectionCount < 1:
            args.areInputsValid = False
class MyInputChangedHandler(adsk.core.InputChangedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: adsk.core.InputChangedEventArgs):
        global _facesIpt, _infoIpt
        if args.input != _facesIpt:
            return
            _facesIpt.commandPrompt = 'select faces'
            _infoIpt.text = '-'
            return
        megArea = getTotalArea()
        _facesIpt.commandPrompt = f'total area:{megArea}'
        _infoIpt.text = megArea
class MyExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: adsk.core.CommandEventArgs):
        area = getTotalArea()
        exportText(area)
class MyCommandDestroyHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        adsk.terminate()
def dumpMsg(s):
    if not DEBUG:
        return
    global _app
    _app.log(f'{s}')
    print(s)
def getTotalArea() -> str:
    global _facesIpt
    area = 0
    for idx in range(_facesIpt.selectionCount):
        face: adsk.fusion.BRepFace = _facesIpt.selection(idx).entity
        area += face.area
    global _app
    unitMgr: adsk.core.UnitsManager = _app.activeProduct.unitsManager
    defUnits = unitMgr.defaultLengthUnits
    units = unitMgr.formatUnits(f'{defUnits}*{defUnits}')
    value = unitMgr.convert(area, unitMgr.internalUnits, units)
    return unitMgr.standardizeExpression(str(value), units)
def exportText(txt: str):
    def getExportPath() -> str:
        dlg: adsk.core.FileDialog = _ui.createFileDialog()
        dlg.title = 'export'
        dlg.isMultiSelectEnabled = False
        dlg.filter = 'Text File(*.txt)'
        if dlg.showSave() != adsk.core.DialogResults.DialogOK:
            return ''
        return dlg.filename
    path = getExportPath()
    if len(path) < 1:
        return
    with open(path, 'w', newline="") as f:
        f.write(txt)
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        cmdDef: adsk.core.CommandDefinition = _ui.commandDefinitions.itemById(
            'kantoku_total_area_cmd'
        if not cmdDef:
            cmdDef = _ui.commandDefinitions.addButtonDefinition(
                'kantoku_total_area_cmd',
                'total_area',
                'total_area'
        global _handlers
        onCommandCreated = MyCommandCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if _ui:
j4n.vokurka
Thank you,
I see what I should take a look at now 🙂
I meant it like this.
User can:
- select a face on a 3D model, change a color of the surface (face), can export an area of coloured surfaces to a local file
kandennti
@j4n.vokurka .
I understand what you mean.
Please give me some time due to the difficulty.
kandennti
@j4n.vokurka .
Due to its large size, the file is attached.
It colors the faces only during the process of selecting faces, but returns to the original color after the command is executed.
The exported file looks like this.
name,count,area
red,1,100.0 mm^2
green,2,200.0 mm^2
blue,3,300.0 mm^2
total,6,600.0 mm^2
j4n.vokurka
Great, this is how it should work. I hope that won't be a problem. Alternatively screenshots should be sufficient. Thank you again for your time and quick response.👍
