Export true *.f3z files with API
oyvindTMNSU
oyvindTMNSU
Is it possible to export true .f3z files with the API? Corresponding to opening a file that have reference designs, go to File->Export and choose f3z? I want to take some local backup, but I don't want to do the manual work of opening every file and export to f3z. Other formats is no problem, I can already do that. f3z however, only gets the ".f3z" name but does not contain the referenced components and drawings.
Somebody knows????
BrianEkins
It's not possible. Actual f3z files are only created on the cloud. When you have an f3z file, it can't be used directly but must be uploaded to the cloud to add the files and set up the relationships between them.
Brian Ekins
oyvindTMNSU
But there is no way to automate the exporting of f3z files? So i don’t need to do it manually for each file?
