Can't copy bodys from occ2 to occ1
maurizio_manzi
maurizio_manzi
I try to copy the bodys of occ2 to occ1.
I don't get an error message, but the bodys was not copied.
After this, the bodys in occ2 and occ2 itself should be deleted.
Best regards
Maurizio
comp1 = occ1.component
comp2 = occ2.component
tempBRepMgr = adsk.fusion.TemporaryBRepManager.get()
baseFeatures = comp1.features.baseFeatures
if baseFeatures.count == 0:
    bfInput = baseFeatures.createInput()
    baseFeature = baseFeatures.add(bfInput)
else:
    baseFeature = baseFeatures.item(0)
try:
    baseFeature.startEdit()
    for body in comp2.bRepBodies:
        if not body.isSolid:
            continue
        bodyCopy = tempBRepMgr.copy(body)
        comp1.bRepBodies.add(bodyCopy, baseFeature)
        body.deleteMe()  # optional
finally:
    baseFeature.finishEdit()
BrianEkins
Here's a light variation of your code that works.
import traceback
import adsk.core
import adsk.fusion
app = adsk.core.Application.get()
ui  = app.userInterface
def run(_context: str):
    des: adsk.fusion.Design = app.activeProduct
    root = des.rootComponent
    occ1 = root.occurrences[0]
    occ2 = root.occurrences[1]
    try:
        baseFeatures = comp2.features.baseFeatures
            baseFeature = baseFeatures.add()
        else:
        try:
            originalBodies = []
            for body in comp1.bRepBodies:
                originalBodies.append(body)
                    continue
                comp2.bRepBodies.add(bodyCopy, baseFeature)
            for body in originalBodies:
                body.deleteMe()
        finally:
    except:  #pylint:disable=bare-except
        # Write the error message to the TEXT COMMANDS window.
        app.log(f'Failed:\n{traceback.format_exc()}')
Brian Ekins
maurizio_manzi
thank you.
I still don't get an error message, but still no bodies are copied.
I've extended the code with messageBoxes (see code), and it looks like it doesn't find any bodies, even though there are definitely some (see construction).
The message box "both occs okay" is displayed, "start edit okay" is also displayed. But "body found: ..." is not displayed.
Best regards
Maurizio
if occ1 != None and occ2 != None:
            ui.messageBox("both occs okay")
            try:
                else:
                try:
                    ui.messageBox("startEdit okay")
                    originalBodies = []
                        ui.messageBox("body found: " + body.name)
                            continue
                        ui.messageBox("body is solid: " + body.name)
                        body.deleteMe()
                finally:
