Export flat patterns to DXF - getting InternalValidationError : smData
gvisca44
gvisca44
Hi there,
with the recent Fusion API updates exposing sheet metal rules, flat patterns etc. I decided it was high time to finish my script to export all flat patterns in a design to DXF.  I have the bulk of the script working, other than iterating the design to choose components that have flat pattern objects.
I initially started iterating:
app = adsk.core.Application.get()
ui = app.userInterface
product = app.activeProduct
design = adsk.fusion.Design.cast(product)
for component in design.allComponents
    if component.activeSheetMetalRule:
        #do something
    else:
        #do something else
However - where a component is NOT a sheet metal component - I receive the following error:
Failed:
Traceback (most recent call last):
File "D:/Users/Public/G2VDesign_OneDrive/OneDrive - G2V DESIGN PTY LTD/Fusion 360 Tools/Add-ins/G2V Flats2DXF/G2V Flats2DXF.py", line 105, in processComponents
File "C:\Users/gvisc/AppData/Local/Autodesk/webdeploy/production/81ea974ab1a66e3de83fe316ff859f913e6ff720/Api/Python/packages\adsk\fusion.py", line 47671, in _get_activeSheetMetalRule
return _fusion.Component__get_activeSheetMetalRule(self)
RuntimeError: 2 : InternalValidationError : smData
I have since found:
    for body in component.bRepBodies:
        if body.isSheetMetal:
            #do something
        else:
            #do something else
...and we are in business !
Is the error above for activeSheetMetalRule correct ? API help indicates I should receive NULL.
Glenn.
BrianEkins
You've run into a bug with the API. It should be returning None in this case and needs to be fixed. I'll see that a bug is filed.
Brian Ekins
gvisca44
Thanks Brian.
For reference in future .. is can you tell me how bugs are logged ?
BrianEkins
Bugs are logged internally by Autodesk. I still have some connections at Autodesk. 😁
Brian Ekins
gvisca44
For future reference - this BUG was resolved in the January 2023 release.
