Exception in running Plane.intersectWithSurface
nnikbin
nnikbin
When I run the following code:
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        origin = adsk.core.Point3D.create(0, 0, 0)
        sphere = adsk.core.Sphere.create(origin, 50)
        normal = adsk.core.Vector3D.create(0, 1, 0)
        plane = adsk.core.Plane.create(origin, normal)
        intersections = plane.intersectWithSurface(sphere)
        if intersections is None:
            ui.messageBox("No Intersections")
        elif intersections.count > 0:
            ui.messageBox("Intersects!")
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
I get the following exception at this line:
Traceback (most recent call last):
File "<string>", line 1, in <module>
File "C:/Users/Navid/AppData/Local/Autodesk/webdeploy/production/4985426b59f0976109b4ac17335cfe5e17f5b1cf/Api/Python/packages\adsk\core.py", line 18309, in intersectWithSurface
return _core.Plane_intersectWithSurface(self, *args)
RuntimeError: 2 : InternalValidationError : err == AcGe::kXXOk
How can I fix it?
KrisKaplan
Unfortunately, it looks like there is a missing dependency in the implementation of Plane.intersectWithSurface API.  There would be nothing you could do to fix this in your script.  I filed a defect on this, and we will hopefully get it fixed for the next update.
Kris
Kris Kaplan
nnikbin
Hi Kris,
Thank you for your response.
Do you have any idea about the release date of the next update?
Navid
KrisKaplan
The next major update that this would likely be in is currently scheduled for the later half of January.
Kris
Kris Kaplan
nnikbin
Thanks Kris
liujac
This issue has been fixed. The fix will be included in the coming update.
Jack
nnikbin
Thanks Jack,
Hope to get the update soon
