Example Script: 'Write user interface to a file API Sample' not working?
Hello F360 Users,
I am trying to get this example script linked below 'Write user iterfcae to a file API Sample', trying to get it to work by running it, then entering the file destination in the dialog box, but it fails to output the file. I will post the error soon, but can anyone confirm that it does in fact work?
Thank you.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-d2b85a7e-fd08-11e4-9e07-3417ebd3d5be
kandennti
This is the working version - the line needing fixing in mentioned in the other answers on this page:
#Author-Autodesk
#Description-Writes out all of the controls in the Fusion UI to a specified text file. This is very useful when positioning your controls within existing Fusion toolbars and panels and positioning your command adjacent to an existing command.
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        dialogResult = ui.messageBox('Create a full report (list and control details) or \nminimal report (control list only)?', 'UI Report Type', adsk.core.MessageBoxButtonTypes.YesNoCancelButtonType, adsk.core.MessageBoxIconTypes.QuestionIconType)
        if dialogResult == adsk.core.DialogResults.DialogYes:
            fullReport = True
        elif dialogResult == adsk.core.DialogResults.DialogNo:
            fullReport = False
        else:
            return
        fileDialog = ui.createFileDialog()
        fileDialog.isMultiSelectEnabled = False
        fileDialog.title = "Specify result filename"
        fileDialog.filter = 'Text files (*.txt)'
        fileDialog.filterIndex = 0
        dialogResult = fileDialog.showSave()
        if dialogResult == adsk.core.DialogResults.DialogOK:
            filename = fileDialog.filename
        else:
            return
        qatToolbar = ui.toolbars.itemById('QAT')
        print(qatToolbar.id)
        # Display the name of all of the existing toolbars.
        result = '** Toolbars (' + str(ui.toolbars.count) + ') **\n'
        for toolbar in ui.toolbars:
            msg = '   ' + toolbar.id + ' (' + str(toolbar.controls.count) + ')____\n'
            result += msg
            result = getControls(toolbar.controls, 2, fullReport, result)
        result += '\n\n** Toolbar Panels (' + str(ui.allToolbarPanels.count) + ')____\n'
        for panel in ui.allToolbarPanels:
            msg = '   ' + panel.id + ' (' + str(panel.controls.count) + ')____\n'
            msg += '      Visible: ' + str(panel.isVisible) + '\n'
            msg += '      Index: ' + str(panel.index) + '\n'
            result += msg
            result = getControls(panel.controls, 2, fullReport, result)
        result += '\n\n** Workspaces  (' + str(ui.workspaces.count) + ')____\n'
        for workspace in ui.workspaces:
            if workspace.productType == '':
                continue
            #msg = '   ' + workspace.id + ' (' + str(workspace.toolbarPanels.count) + ')____\n'
            msg = '   ' + workspace.id + ' (' + str(len(workspace.toolbarPanels)) + ')____\n'
            result += msg
            for panel in workspace.toolbarPanels:
                msg = '      ' + panel.id + '\n'
                result += msg
        output = open(filename, 'w')
        output.writelines(result)
        output.close()
        ui.messageBox('File written to "' + filename + '"')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
# Function used to recursively traverse the controls.
def getControls(controls, level, fullReport, result):
    for control in controls:
        if control.objectType == adsk.core.SeparatorControl.classType():
            msg = ((level*3)*' ') + '-Separator-\n'
            msg += (((level+1)*3)*' ') + 'Control ID: ' + control.id + '\n'
            msg += (((level+1)*3)*' ') + 'isVisible: ' + str(control.isVisible) + '\n'
            msg += (((level+1)*3)*' ') + 'index: ' + str(control.index) + '\n'
            result += msg
        else:
            if control.objectType == adsk.core.CommandControl.classType():
                msg = ((level*3)*' ') + 'Command Control____\n'
                if fullReport:
                    try:
                        msg += (((level+1)*3)*' ') + 'isPromoted: ' + str(control.isPromoted) + '\n'
                        msg += (((level+1)*3)*' ') + 'isPromotedByDefault: ' + str(control.isPromotedByDefault) + '\n'
                    except:
                        # Failed to get isPromoted so do nothing.
                        pass
                    msg += (((level+1)*3)*' ') + 'Command Definition____\n'
                    try:
                        commandDef = control.commandDefinition
                        if commandDef:
                            msg += (((level+2)*3)*' ') + 'Definition ID: ' + control.commandDefinition.id + '\n'
                            msg += (((level+2)*3)*' ') + 'Control Definition____\n'
                            controlDef = commandDef.controlDefinition
                            msg += (((level+3)*3)*' ') + 'Name: ' + controlDef.name + '\n'
                            msg += (((level+3)*3)*' ') + 'isEnabled: ' + str(controlDef.isEnabled) + '\n'
                            msg += (((level+3)*3)*' ') + 'isVisible: ' + str(controlDef.isVisible) + '\n'
                            if controlDef.objectType == adsk.core.ButtonControlDefinition.classType():
                                msg += (((level+3)*3)*' ') + 'Type: ButtonControlDefinition\n'
                            elif controlDef.objectType == adsk.core.CheckBoxControlDefinition.classType():
                                msg += (((level+3)*3)*' ') + 'Type: CheckBoxControlDefinition\n'
                                msg += (((level+3)*3)*' ') + 'isChecked: ' + str(controlDef.isChecked) + '\n'
                            elif controlDef.objectType == adsk.core.ListControlDefinition.classType():
                                msg += (((level+3)*3)*' ') + 'Type: ListControlDefinition\n'
                                if controlDef.listControlDisplayType == adsk.core.ListControlDisplayTypes.CheckBoxListType:
                                    displayType = 'Check box list'
                                elif controlDef.listControlDisplayType == adsk.core.ListControlDisplayTypes.RadioButtonlistType:
                                    displayType = 'Radio button list'
                                elif controlDef.listControlDisplayType == adsk.core.ListControlDisplayTypes.StandardListType:
                                    displayType = 'Standard list'
                                msg += (((level+3)*3)*' ') + 'Displayed as: ' + displayType + '\n'
                                msg += (((level+3)*3)*' ') + 'lastSelected: ' + str(controlDef.lastSelected.name) + '\n'
                                msg += (((level+3)*3)*' ') + 'List Items\n'
                                for listItem in controlDef.listItems:
                                    if listItem.isSeparator:
                                        msg += (((level+4)*3)*' ') + '-Separator-\n'
                                    else:
                                        msg += (((level+4)*3)*' ') + 'name: ' + listItem.name + ', isSelected: ' + str(listItem.isSelected) + '\n'
                            else:
                                msg += (((level+3)*3)*' ') + '**Unexpected type of control definition.\n'
                    except:
                        msg += (((level+2)*3)*' ') + 'Unable to get the associated CommandDefinition.\n'
                result += msg
            elif control.objectType == adsk.core.DropDownControl.classType():
                msg = ((level*3)*' ') + 'Drop Down Control (' + str(control.controls.count) + ')____\n'
                msg += (((level+1)*3)*' ') + 'ID: ' + control.id + '\n'
                result += msg
                result = getControls(control.controls, level+1, fullReport, result)
            elif control.objectType == adsk.core.SplitButtonControl.classType():
                msg = ((level*3)*' ') + 'Split Button Control____\n'
                if fullReport:
                    msg += (((level+1)*3)*' ') + 'isLastUsedShown: ' + str(control.isLastUsedShown) + '\n'
                    msg += (((level+1)*3)*' ') + 'default Command: ' + control.defaultCommandDefinition.id + '\n'
                    msg += (((level+1)*3)*' ') + '+ Additional associated controls:\n'
                    try:
                        for cmdDef in control.additionalDefinitions:
                            msg += (((level+2)*3)*' ') + cmdDef.id + '\n'
                    except:
                        result += msg
                        continue
                result += msg
            else:
                ctype = control.objectType.split('::')[2]
                msg = ((level*3)*' ') + '*****' + control.id + ', type: ' + ctype + ', visible: ' + str(control.isVisible) + '\n'
                result += msg
    return result
This version doesn't work for me either.  I get the same error as before.
OceanHydroAU
If you're only looking for the output - find attached one I saved from a few months ago - it's extremely useful for figuring out where to place new menu items!
This helps alot.  Thanks
Thank you!
Sorry I got pulled away on another project, I appreciate the reply. Yeah it seems like there is a bit of fiddling to be done on some example scripts. Glad this is working at least.
