Edit CAM operation settings by script (Change Curve selection sequence)?
Hi there,
Is it possible the Edit CAM operation settings by script? or Change Curve selection sequence and direction in operation settings?
I saw there are only a few examples in CAM API , but only to the setup and operation items.
Please see the pictures below, when setting the multi-axis contour--Geometry--curve selection, if I select one by one,
and change direction if needed, the route will be good, but if there are hundreds of lines, it's waste of time.
And if i select the sketch to get the route in the sketch, it is a bad route like what we found in the picture.
there was even a big mistake in the left down corner of the second picture, upper the rectangle.
So I want to change the route when setting operations using scripts and some algorithm, I hope the route in yellow as less as possible.
is it possible to do it using the API we have now?
Thanks very much!
Terry
marshaltu
Unfortunately the part of CAM API aren't available yet. I would like to recommend you log a request in our IdeaStation.
https://forums.autodesk.com/t5/fusion-360-ideastation-request-a/idb-p/125
Marshal
Marshal Tu
Fusion Developer
Hi Marshal Tu,
Thanks for your reply.
