Duplicate a sketch on the opposite side.
Hi all
I have some beginner problems with API. I want to select some face and sketch circle 10mm from some edge (or center of this face. centroid?) Then make extrude and rectangular pattern. Issue I have on left side that sketch goes outside of the face
right sideright sideleft sideleft side
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        design = app.activeProduct
        rootComp = adsk.fusion.Component.cast(design.rootComponent)
        sketches = rootComp.sketches
        faceSel = ui.selectEntity('Select a face', 'Faces')
        if faceSel:
            selectedFace = adsk.fusion.BRepFace.cast(faceSel.entity)
            sketch = sketches.add(selectedFace)
            circles = sketch.sketchCurves.sketchCircles
            circle1 = circles.addByCenterRadius(adsk.core.Point3D.create(2,1,0),0.5)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Create, not duplicate, sry
kandennti
Hi stupadmitry.
The algorithm on the opposite side is not so good,
but we will create an circle on the selected surface.
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        if faceSel:
#            circle1 = circles.addByCenterRadius(adsk.core.Point3D.create(2,1,0),0.5)
            #coordinate
            circle_center_pos = [2, 1, 0]
            UVpos_try_list = [circle_center_pos ,
                             [circle_center_pos[0]*-1,circle_center_pos[1],0],
                             [circle_center_pos[0],circle_center_pos[1]*-1,0],
                             [circle_center_pos[0]*-1,circle_center_pos[1]*-1],0]
            #Evaluator
            surfEva = adsk.core.SurfaceEvaluator.cast(selectedFace.evaluator)
            for pos in UVpos_try_list:
                #create circle
                    adsk.core.Point3D.create(pos[0],pos[1],pos[2]),0.5)
                center = circle1.centerSketchPoint.worldGeometry
                #parameter
                returnValue, center_prm = surfEva.getParameterAtPoint(center)
                if not returnValue :
                    circle1.deleteMe()
                    continue
                #judgment
                if surfEva.isParameterOnFace(center_prm):
                    break
                else:
                    circle1.deleteMe()
            ui.messageBox('Done')
    except:
        if ui:
Use the 'BRepFace.evaluator.isParameterOnFace' method to determine
if the center of the circle is on the surface.
