Drive Revolute Joint and Combine (Cut) Two Bodies Multiple Times
lukas94R89KL
lukas94R89KL
I am essentially trying to cut out a gear from another gear I already formed. For that I can use a combine (cut) operation followed by a step in the revolute joint. I can then do another combine-command (before which I have to select: Capture Position) and thereby cut out an approximate shape of a gear. I did this manually a few times and it worked, but took ages so I tried to use the API. Here is what I came up with:
import adsk.core, adsk.fusion, adsk.cam, traceback
import math, time
combineFeatures = None
def cut(targetBody: adsk.fusion.MeshBody, toolBodies: adsk.core.ObjectCollection) -> adsk.fusion.MeshBody:
# Create New Combine Feature
    combineFeatureInput = combineFeatures.createInput(targetBody, toolBodies)
    # Set Up
    combineFeatureInput.operation = 1 # Cut
    combineFeatureInput.isKeepToolBodies = True
    combineFeatureInput.isNewComponent = False
    # Add To CombineFeatures
    return combineFeatures.add(combineFeatureInput)
def run(context):
  ui = None
  try:
# Get Base
    app = adsk.core.Application.get()
    ui  = app.userInterface
    des = adsk.fusion.Design.cast(app.activeProduct)
# Get Revolute Joint (Gear2)
    root = des.rootComponent
    joint = root.asBuiltJoints.itemByName('Rev1')
    rev = adsk.fusion.RevoluteJointMotion.cast(joint.jointMotion)
# Get The Components (Gear1 & Gear2)
    occs = root.occurrences
    comp1 = occs.item(0).component
    comp2 = occs.item(1).component
# Get The Gear-Mesh-Bodies
    gear1 = comp1.bRepBodies[0]
    gear2 = comp2.bRepBodies[0]
# Pack gear1 In Collection (As Combine-Cut Requires toolBodies As A Collection)
    cutters = adsk.core.ObjectCollection.create()
    cutters.add(gear1)
# Get List Of All Combine Features/Commands & Set Globally
    features = comp2.features
    global combineFeatures
    combineFeatures = features.combineFeatures
# Set Up To Group All Cut-Commands For Easy Deletion
    cutFeature = None
    firstCutIndex = None
# Cutting
    for i in range(10):
    # Revolve
        rev.rotationValue = i * (math.pi/180) # increment revolve by 1deg
        adsk.doEvents() # force revolution update
    # Cut
        cutFeature = cut(gear2, cutters)
        if firstCutIndex == None:
            firstCutIndex = cutFeature.timelineObject.index # set start index for grouping
        time.sleep(1) # timeout to see each cut
# Group All Commands
    lastCutIndex = cutFeature.timelineObject.index
    timelineGroups = des.timeline.timelineGroups
    timelineGroup = timelineGroups.add(firstCutIndex, lastCutIndex)
    timelineGroup.name = 'Revolve-Cuts'
  except:
    if ui:
      ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
I could swear, that it already worked in between. Earlier I was able to see the correct cuts, but when the script terminated, all cuts became invisible but the first one. Now it rotates, but does not show any cutting. I kind of suspect that I need to capture the position somehow or update my gear2 any other way for the program to mind the rotation. Any help appreciated!
lukas94R89KL
That‘s amazing! Yours is much better than mine. I‘ll take a look at it. I still wonder why my code is not working. This API seems pretty complicated to me.
lukas94R89KL
Hello @kandennti
your solution is much nicer than mine, yet I have a problem with it: It does not allow for more complicated scenarios, like having a asymmetric 3D gear (e.g. a helical gear or something even more complicated), or having two gears that rotate in different axles and/or translate while rotating. I would really like to keep my approach driving the joint and then cutting the two parts, as it is much more versatile. I just don't understand why exactly my code is not working. I send the file I use to test the script I send earlier.
Thanks, Lukas
lukas94R89KL
I updated the code. It should be more readable now.
kandennti
@lukas94R89KL -San.
If you do not execute the snapshots.add method after moving the occurrence, it will return to its original position.
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/transformation-on-occurrence-getting-reset...
You will also get a warning dialog in the GUI.
I think a modification like this would give you the process you want.
# Cutting
    for i in range(10):
    # Revolve
        try:
           des.snapshots.add()
        except:
           pass
