DogBone Add-in
DogBone Add-in
Alexrose1942
DogBone Add-in
Alexrose1942
Hi
DogBone add-in doesn't appear although I followed instruction and added the folder under : c:\Users\xxy\AppData\Roaming\Autodesk\Autodesk Fusion 360\API\AddIns\Dogbone-master\
marshaltu
You can hit "+" button beside "My Add-Ins" in "Script & Add-Ins" dialog to add addin. You can select the folder "c:\Users\xxy\AppData\Roaming\Autodesk\Autodesk Fusion 360\API\AddIns\Dogbone-master\" to add the Dogbone addin.
Marshal
Marshal Tu
Fusion Developer
