documentation bug: Document and Assembly Structure
The first python example on this page does not work (any more?):
app = adsk.core.Application.get()
ui = app.userInterface
design = adsk.fusion.Design(app.activeProduct) ### <<--- no constructor defined
if not design:
    ui.messageBox('No active Fusion 360 design', 'No Design')
    return
The line in the middle should probably be
design = adsk.fusion.Design.cast(app.activeProduct)
BrianEkins
It's a mistake in the documentation. I'm fairly certain that I wrote that block of code in a text editor, along with the rest of that article, and not in an IDE. So it's my mistake and it should be using the cast property as you guessed.
Brian Ekins
Inventor and Fusion 360 API Expert
Website/Blog: https://EkinsSolutions.com
BrianEkins
Thanks for the reminder.
Brian Ekins
