Disable timeout while debugging in VS Code
lorraine5RWGT
lorraine5RWGT
Disable timing out while debugging in VS Code.  Can't debug anything because it times out too quickly. Can't re-run scripts from VS Code without restarting either.  It's a pain because I have to re-open everything and can't remember where I left off and don't have the workspace I left off at.  I literally can't work anything right now.
I can't even debug my importing because not being able to run scripts directly from Spyder has forced me to change the structure of my code and importing.
Also, it would be good to enable running scripts from VS Code in Fusion like it worked in Spyder.
Archana_Gurav
Hi @lorraine5RWGT
We have logged your issue UP-44057. We will get back to you with solution.
Thanks for your time.
Archana
Archana Gurav
Software Developer Fusion 360
LinkedIn
Autodesk, Inc.
Archana_Gurav
Now with October release there is support for running/rerunning script from VSCode when launched in edit or debug mode from fusion and completely disabled the time out. This might help with your issue.
Please refer below post by @goyals
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/some-vscode-fixes-delivered-with-fusion-oc...
Thanks and Regards,
Archana
Archana Gurav
LinkedIn
Autodesk, Inc.
lorraine5RWGT
Yay! Thank you
