Different undo behaviors between API and UI
mycad2016D8W4P
mycad2016D8W4P
Run the script to create two sketch lines, the undoes are list in sub levels. Do the same operations on UI, the undoes are all list in first level. Why the api undoes are grouped but not the UI's?
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        design = app.activeProduct
        # Get the root component of the active design.
        rootComp = design.rootComponent
        # Create a new sketch on the xy plane.
        sketches = rootComp.sketches;
        xyPlane = rootComp.xYConstructionPlane
        sketch = sketches.add(xyPlane)
        # Draw two connected lines.
        lines = sketch.sketchCurves.sketchLines;
        line1 = lines.addByTwoPoints(adsk.core.Point3D.create(0, 0, 0), adsk.core.Point3D.create(3, 1, 0))
        line2 = lines.addByTwoPoints(line1.endSketchPoint, adsk.core.Point3D.create(1, 4, 0))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
marshaltu
That was known issue. API has different transaction logic from UI so that the items with same "names" in undo list will be grouped if they are next to each other. And the names for the same operation(e.g. draw rectangle with two points) in API and UI are different. But the undo behaviors for both API and UI should be same.
As you may be also aware, the undo list generated by API will not be localized.
Marshal
Marshal Tu
Fusion Developer
