Determining JointInput.angle to use for Joint creation
balunist
balunist
I need a way to determine the appropriate angle to use when creating a face to sketch profile CenterKeyPoint joint using a face from a body
that is not aligned with x, y, or z axis.
Run the script below and step through the history to see the problem I need to solve or view the screencast.
Thanks in advance!
import adsk.core, adsk.fusion, traceback
# class used to pass position and size of desired rectangle taking default units as input
class rect:
def __init__(self, insert=(0, 0), size=(0, 0)):
app = adsk.core.Application.get()
design = adsk.fusion.Design.cast(app.activeProduct)
self.unitsManager = design.unitsManager
x = self.convertToInternal(insert[0])
y = self.convertToInternal(insert[1])
self.defaultLength = size[0]
self.defaultWidth = size[1]
self.length = self.convertToInternal(size[0])
self.width = self.convertToInternal(size[1])
self.startPoint = adsk.core.Point3D.create(x, -y, 0)
self.endPoint = adsk.core.Point3D.create(x + self.length, -(y + self.width), 0)
def convertToInternal(self, valueIn):
return self.unitsManager.convert(valueIn, self.unitsManager.defaultLengthUnits, self.unitsManager.internalUnits)
# find the largest face and it's length & width edges for a body
class findMatchFace:
def __init__(self, body):
faceAreas = []
for face in body.faces:
faceAreas.append(face.area)
idx = faceAreas.index(max(faceAreas))
self.face = body.faces.item(idx)
edgeLengths = []
for edge in self.face.edges:
edgeLengths.append(edge.length)
idx = edgeLengths.index(max(edgeLengths))
self.edge = self.face.edges.item(idx)
self.lengthVector = self.edgeToVector(self.edge)
self.widthVector = None
vector = self.edgeToVector(edge)
if vector.isPerpendicularTo(self.lengthVector):
self.widthVector = vector
break
def edgeToVector(self, edge):
v1x = edge.startVertex.geometry.x
v1y = edge.startVertex.geometry.y
v1z = edge.startVertex.geometry.z
v2x = edge.endVertex.geometry.x
v2y = edge.endVertex.geometry.y
v2z = edge.endVertex.geometry.z
return adsk.core.Vector3D.create(v2x-v1x, v2y-v1y, v2z-v1z)
# class used to map component bodies to a board on xy plane
class mapper:
def __init__(self):
self.sketch = None
self.boardNum = 0
self.app = adsk.core.Application.get()
self.ui = self.app.userInterface
self.design = adsk.fusion.Design.cast(self.app.activeProduct)
self.rootComp = self.design.rootComponent
self.mapOcc = self.rootComp.occurrences.addNewComponent(adsk.core.Matrix3D.create())
self.mapComp = self.mapOcc.component
self.mapComp.name = 'map'
self.xYPlane = self.mapComp.xYConstructionPlane
lib = self.app.materialLibraries.itemByName('Fusion 360 Material Library')
self.paperMaterial = lib.materials.itemByName('Paper')
def _newSketch(self, compOcc=None, offset=0):
try:
if offset == 0:
self.sketch = compOcc.component.sketches.add(self.xYPlane)
else:
offsetValue = adsk.core.ValueInput.createByReal(offset)
planes = self.mapOcc.component.constructionPlanes
planeInput = planes.createInput()
planeInput.setByOffset(self.xYPlane, offsetValue)
plane = planes.add(planeInput)
self.sketch = compOcc.component.sketches.add(plane)
self.sketchLines = self.sketch.sketchCurves.sketchLines
self.sketchTexts = self.sketch.sketchTexts
except:
self.ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def _add(self, rect):
sketchLines = self.sketchLines.addTwoPointRectangle(rect.startPoint, rect.endPoint)
return sketchLines
def addBoard(self, rect):
self.boardOcc = self.mapComp.occurrences.addNewComponent(adsk.core.Matrix3D.create())
self.boardComp = self.boardOcc.component
self.boardNum += 1
self.boardName = 'Board {}'.format(self.boardNum)
self.boardComp.name = self.boardName
self._newSketch(compOcc=self.boardOcc)
self.sketch.name = self.boardName
self._add(rect)
idx = len(self.sketch.profiles) - 1
prof = self.sketch.profiles.item(idx)
# Create the patch feature
patches = self.boardComp.features.patchFeatures
patchInput = patches.createInput(prof, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
patchFeature = patches.add(patchInput)
self.boardBody = patchFeature.bodies.item(0)
self.boardBody.name = self.boardName
self.boardBody.material = self.paperMaterial
def addComponent(self, source, targetRect, name):
self.body = source.body
self.compOcc = self.boardComp.occurrences.addNewComponent(adsk.core.Matrix3D.create())
self.compComp = self.compOcc.component
self.compComp.name = name
self._newSketch(self.boardOcc)
self.sketch.name = '{}{}'.format(name, "_target")
self._add(targetRect)
targetProf = self.sketch.profiles.item(idx)
self.mapJoint(self.compOcc, targetProf, source)
def mapJoint(self, compOcc, targetProf, source):
self.body.copyToComponent(compOcc)
self.bodyOcc = compOcc.bRepBodies.item(0)
matchFace = findMatchFace(self.bodyOcc)
# Create the first joint geometry with the end face
geo0 = adsk.fusion.JointGeometry.createByPlanarFace(matchFace.face, None, adsk.fusion.JointKeyPointTypes.CenterKeyPoint)
# Create the second joint geometry with the sketch profile
geo1 = adsk.fusion.JointGeometry.createByProfile(targetProf, None, adsk.fusion.JointKeyPointTypes.CenterKeyPoint)
# Create joint input
joints = self.rootComp.joints
jointInput = joints.createInput(geo0, geo1)
jointInput.angle = source.angle
jointInput.isFlipped = True
# Create the joint
joints.add(jointInput)
self.bodyOcc.material = self.paperMaterial
# This class will create a body which will be moved to serveral alignments with
# respect to x,y,z axis, copied, then mapped to a sketch profile with a joint.
class createSourceComponent:
def __init__(self):
actDoc = app.activeDocument.dataFile
if actDoc != None:
app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
self.rootComp = design.rootComponent
occs = self.rootComp.occurrences
for occ in occs:
if occ.component.name.startswith('map'):
occ.deleteMe()
break
for occ in occs:
occ.deleteMe()
break
mapSourceOcc = rootComp.occurrences.addNewComponent(adsk.core.Matrix3D.create())
self.mapSourceComp = mapSourceOcc.component
self.mapSourceComp.name = 'mapSource'
sketches = self.mapSourceComp.sketches
sketch = sketches.add(self.rootComp.xYConstructionPlane)
sketchLines = sketch.sketchCurves.sketchLines
compRect = rect(insert=(0, -4), size=(18, 4))
self.length = compRect.defaultLength
self.width = compRect.defaultWidth
self.thick = .75 * 2.54
sketchLines.addTwoPointRectangle(compRect.startPoint, compRect.endPoint)
self.targetProf1 = sketch.profiles.item(0)
profiles = adsk.core.ObjectCollection.create()
profiles.add(self.targetProf1)
extrudeFeats = self.mapSourceComp.features.extrudeFeatures
extrudeFeature = extrudeFeats.addSimple(profiles,
adsk.core.ValueInput.createByReal(self.thick),
self.body = extrudeFeature.bodies.item(0)
self.bodies = adsk.core.ObjectCollection.create()
self.bodies.add(extrudeFeature.bodies.item(0))
chkRotate = checkRotate(self.body)
self.isRotate = chkRotate.isRotate
self.angle = chkRotate.angle
self.odd = chkRotate.odd
def move(self, vector):
transform = adsk.core.Matrix3D.create()
transform.translation = vector
moveFeats = self.mapSourceComp.features.moveFeatures
moveFeatureInput = moveFeats.createInput(self.bodies, transform)
moveFeats.add(moveFeatureInput)
def rotate(self, angle, axis, origin):
transform.setToRotation(angle, axis, origin)
# check body orientation with respect to X,Y,Z axis & determine if rotation is
# required when assemble joint is created with sketch profile in XY plane
RadFor90 = round(1.5707963267948966, 3) # 90 deg in radians
class checkRotate:
source = findMatchFace(body)
lengthVector = source.lengthVector
widthVector = source.widthVector
xVector = design.rootComponent.xConstructionAxis.geometry.direction
yVector = design.rootComponent.yConstructionAxis.geometry.direction
zVector = design.rootComponent.zConstructionAxis.geometry.direction
aList = []
aList.append(round(lengthVector.angleTo(xVector), 3)) # 0 - lengthToX
aList.append(round(widthVector.angleTo(xVector), 3)) # 1 - widthToX
aList.append(round(lengthVector.angleTo(yVector), 3)) # 2 - lengthToY
aList.append(round(widthVector.angleTo(yVector), 3)) # 3 - widthToY
aList.append(round(lengthVector.angleTo(zVector), 3)) # 4 - lengthToZ
self.odd = self.chkOriented(aList)
aList.append(round(widthVector.angleTo(zVector), 3)) # 5 - widthToZ
self.isRotate = False
self.angle = adsk.core.ValueInput.createByReal(0)
t1 = (aList[0] == RadFor90 and aList[1] == 0)
t2 = (aList[1] == RadFor90 and aList[0] == 0 and aList[4] != RadFor90)
t3 = ((aList[0] == RadFor90) and (aList[1] == RadFor90)) and ((aList[4] != 0) and (aList[2] != RadFor90))
t4 = (aList[0] == RadFor90 and aList[3] == RadFor90)
# print('t1 {} t2 {} t3 {} t4 {}'.format(t1, t2, t3, t4))
if (t1 or t2 or t3 or t4):
self.angle = adsk.core.ValueInput.createByReal(-RadFor90)
self.isRotate = True
print('>*>*>*>* -90 angle rotate required!')
if self.odd:
print('>*>*>*>* special angle required!')
print('>>>>> {} - rotate: {} odd: {} lengthToX: {} widthToX: {} lengthToY: {} widthToY: {} lengthToZ: {} widthToZ: {}'.format(
body.name,self.isRotate,self.odd, aList[0], aList[1], aList[2], aList[3], aList[4], aList[5]))
def chkOriented(self, aList):
hasOdd = False
hasNormal = False
for angle in aList:
if angle != RadFor90 and angle != 0:
hasOdd = True
else:
hasNormal = True
return hasOdd and not hasNormal
# Create a demo showing the issue I am having with a face to profile CenterKeyPoint
# joint assembly. I need a way to determine the appropriate angle to use
# when creating a face to profile CenterKeyPoint joint using face from a body
# that is not aligned with x,y, or z.
def run(context):
ui = app.userInterface
try:
# length 0 deg to X, width 0 deg to Y, length & width 90 deg to Z
source = createSourceComponent()
# rotate on Y 45 deg to X and Z axis
angle = -0.785398 # -45 degrees
axis = adsk.core.Vector3D.create(0.0, 10.0, 0.0)
origin = adsk.core.Point3D.create(0.0, 0.0, 0.0)
source.rotate(angle, axis, origin)
mapBody = mapper()
boardRect = rect(insert=(0,0), size=(96,12))
mapBody.addBoard(boardRect)
xOffset = 0
yOffset = 0
compRect = rect(insert=(xOffset, yOffset), size=(source.length, source.width))
mapBody.addComponent(source, compRect, 'Y45ToXandZ')
# rotate on X 45 deg to Y and Z axis
axis = adsk.core.Vector3D.create(10, 0.0, 0.0)
xOffset += source.length
mapBody.addComponent(source, compRect, 'X45ToYandZ')
# rotate on Z 45 deg to X and Y axis
axis = adsk.core.Vector3D.create(0.0, 0.0, 10)
mapBody.addComponent(source, compRect, 'Z45ToXandY')
camera_ = app.activeViewport.camera
camera_.isFitView = True
app.activeViewport.camera = camera_
except:
if ui:
balunist
Post did not pick up my screencast.  Here it is ..
marshaltu
I tried to reproduce your issue. Unfortunately I cannot get the sample script you posted run because of format issue.
It would be great if you can repost your codes by using "Insert Code" command (like as below).
Marshal
class rect:
        faceAreas = []
        edgeLengths = []
                break
class mapper:
    def __init__(self):
        self.sketch = None
        self.boardNum = 0
        try:
            if offset == 0:
            else:
        except:
        return sketchLines
        self.boardNum += 1
        self._add(rect)
        # Create the joint
    def __init__(self):
        if actDoc != None:
        for occ in occs:
                occ.deleteMe()
                break
        for occ in occs:
                occ.deleteMe()
                break
class checkRotate:
        aList = []
        if self.odd:
        hasOdd = False
        hasNormal = False
        for angle in aList:
                hasOdd = True
            else:
                hasNormal = True
def run(context):
    try:
        mapBody = mapper()
        xOffset = 0
        yOffset = 0
    except:
        if ui:
Marshal Tu
Fusion Developer
balunist
Created on Mon Jan 29 16:42:20 2018
@author: icarus
class rect:
        faceAreas = []
        edgeLengths = []
                break
class mapper:
    def __init__(self):
        self.sketch = None
        self.boardNum = 0
        try:
            if offset == 0:
            else:
        except:
        return sketchLines
        self.boardNum += 1
        self._add(rect)
        # Create the joint
    def __init__(self):
        if actDoc != None:
        for occ in occs:
                occ.deleteMe()
                break
        for occ in occs:
                occ.deleteMe()
                break
        self.widthInternal = compRect.width
class checkRotate:
        aList = []
        if self.odd:
        hasOdd = False
        hasNormal = False
        for angle in aList:
                hasOdd = True
            else:
                hasNormal = True
def run(context):
    try:
        mapBody = mapper()
        xOffset = 0
        yOffset = 0
    except:
        if ui:
marshaltu
Thank you for the codes. I can run them now. I am not sure if I get your point correctly. If you know the direction of long edge of "Board" body you created and the vector of side face of "mapSource" body, you should be able to use them to calculate the angle and create joint with alignment. I have no better idea.
Marshal
Marshal Tu
Fusion Developer
balunist
Marshal,
Thanks for your response.   I was hoping to find a way to calculate the necessary angle to specify on the jointInput.angle.   I measured the resulting angle as 30.4 degrees (0.5305801 radians).  If I specify that angle on in the joinInput.angle prior to the joints.add it is aligned.   Make the following change  at line 271 in the checkRotate class and you will see what I mean.
if self.odd:
angleNeeded = -0.5305801 # determine this angle based on body pre-position
self.angle = adsk.core.ValueInput.createByReal(angleNeeded)
balunist
OK, I believe I have a way to calculate the angle.    Here is the modified mapJoint method to measure the angle between the two occurrences provide by the resultant joint.
Thanks!
        # Create the joint
        joint = joints.add(jointInput)
        # check angle occurances and if not zero delete joint, combine angle with inital angle, and redo joint
        occOne = joint.occurrenceOne
        bodyOneProxy = occOne.bRepBodies.item(0)
        newSourceOne = findMatchFace(bodyOneProxy)
        occTwo = joint.occurrenceTwo
        bodyTwoProxy = occTwo.bRepBodies.item(0)
        newSourceTwo = findMatchFace(bodyTwoProxy)
        measureResult = self.app.measureManager.measureAngle(newSourceOne.edge, newSourceTwo.edge)
        angle = measureResult.value
        if angle != 0:
            print('>>>>> Angle between source and target {}'.format(angle))
            joint.deleteMe()
            jointInput.angle = adsk.core.ValueInput.createByReal(source.angle.realValue - angle)
