Determine if open document is a Drawing
isocam
isocam
Can anybody help?
Is it possible, using a Fusion 360 Python script to determine if an open document is a "Drawing"?
Many thanks!!!!
Darren
kandennti
Hi @isocam .
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui: adsk.core.UserInterface = None
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        doc: adsk.core.Document = app.activeDocument
        if doc.objectType == 'adsk::drawing::DrawingDocument':
            msg = '.f2d'
        elif doc.objectType == 'adsk::fusion::FusionDocument':
            msg = '.f3d or .f3z'
        else:
            msg = 'pcb'
        ui.messageBox(msg)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
zxynine
Its not always a good idea to use strings to represent class types. A more idealised version (IMO) would be:
import traceback
import adsk.fusion, adsk.core, adsk.drawing
def run(context):
    try:
        if doc.objectType == adsk.drawing.DrawingDocument.objectType:
            msg = '.f2d'
        elif doc.objectType == adsk.fusion.FusionDocument.objectType:
        else:
            msg = 'pcb'
        ui.messageBox(msg)
    except:
        if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
zxynine
You can also just use type to compare so:
import traceback
def run(context):
    try:
        docType: type = type(app.activeDocument)
        if docType is adsk.drawing.DrawingDocument:
            msg = '.f2d'
        elif docType is adsk.fusion.FusionDocument:
        else:
            msg = 'pcb'
        ui.messageBox(msg)
    except:
Or you can use the 'isinstance' func:
import traceback
def run(context):
    try:
        if isinstance(doc,adsk.drawing.DrawingDocument):
            msg = '.f2d'
        elif isinstance(doc,adsk.fusion.FusionDocument):
        else:
            msg = 'pcb'
        ui.messageBox(msg)
    except:
Im sure there's a slight difference in the performance of each, however for general purposes, they are all functionally equivalent.
kandennti
@zxynine .
Certainly, this is safer, since strings can be changed.
I learned a lot.
