Determine if object is part of base class
SeanKane88
SeanKane88
Is it possible to determine if an object is part of a base / parent class? I.e. I would to do the following check:
if (ObjectType == ObjectParentType):
    my code here
Object is a sketchLine or a sketchArc. From the reference manual I know that these are both inherited from sketchCurve. However, I can't figure out how to get the parent type from the sketchLine / Arc etc. so every test I have been able to do ends up failing because the equality ends up being something like sketchLine == sketchCurve, which fails.
ekinsb
This is discussed in the "Python Specific Issues" topic in the API help.  Here's a direct link that shows you can use the Python isInstance function.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-743C88FB-CA3F-44B0-B0B9-FCC378D0D782#Object Types
Brian Ekins
Mod the Machine blog
SeanKane88
Thanks - works fine. Sorry about the slow response but have been away from my computer a week.
