Deleted joints stays in the design
sandeepdutta
sandeepdutta
Hello All,
I am using the script from https://github.com/yanshil/Joint2Graphviz/tree/bd3ed01a64965c4844b88c9b1720cddb1a4c4b35
to create a visualization for my joint hierarchy. When I walk through the joints using
for joint in root.joints:
I see some joints that I cannot find in the browser, what can cause this ?
How do I workaround this problem.
Thank you in advance.
Sandeep
BrianEkins
Can you provide a design that demonstrates the problem?
Brian Ekins
Inventor and Fusion 360 API Expert
Website/Blog: https://EkinsSolutions.com
sandeepdutta
Sure here is the link
https://a360.co/3QZtsFt
Please let me know if you need anything more.
Sandeep
BrianEkins
I am seeing a problem and want to confirm if it is the same problem you're seeing. I dumped out the list of joints in the root component using Design.rootComponent.joints, and then I compared this list to the list in the browser. I found that the joint "Rigid45" was found by the API but is not listed in the browser. I also found that the joint "Rev1" is shown in the browser but was not found by the API. Is that what you see too, or are you seeing something else?
Brian Ekins
sandeepdutta
Yes that is correct, those are the two joints I am having trouble with.
Thank you
Sandeep
