Delete operations on "Timeline" space
How do this using API?
marshaltu
You cannot delete operations directly from timeline. Instead you can delete corresponding features and then the item in timeline will be gone as well. The following codes demo how to delete the second extrude feature from timeline.
Marshal
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        design = adsk.fusion.Design.cast(app.activeProduct)
        extrude = adsk.fusion.ExtrudeFeature.cast(design.timeline.item(1).entity)
        extrude.deleteMe()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Marshal Tu
Fusion Developer
