My code is mostly taken from the "bolt" example. I've changes it so that the user selects a face (lines 87-89) and then that face is used as the sketch plane (line 139). The problem is that I need to define face1 and I don't know where or how to do this in the code. I'm sure it is something simple that I am just overlooking. I really appreciate the help.
#Author-Autodesk Inc.
#Description-Create bolt
import adsk.core, adsk.fusion, traceback
import math
defaultBoltName = 'Bolt'
defaultBodyLength = .635
# global set of event handlers to keep them referenced for the duration of the command
handlers = []
app = adsk.core.Application.get()
if app:
ui = app.userInterface
newComp = None
def createNewComponent():
# Get the active design.
product = app.activeProduct
design = adsk.fusion.Design.cast(product)
rootComp = design.rootComponent
allOccs = rootComp.occurrences
newOcc = allOccs.addNewComponent(adsk.core.Matrix3D.create())
return newOcc.component
class BoltCommandExecuteHandler(adsk.core.CommandEventHandler):
def __init__(self):
super().__init__()
def notify(self, args):
try:
unitsMgr = app.activeProduct.unitsManager
command = args.firingEvent.sender
inputs = command.commandInputs
bolt = Bolt()
for input in inputs:
if input.id == 'boltName':
bolt.boltName = input.value
elif input.id == 'bodyLength':
bolt.bodyLength = adsk.core.ValueInput.createByString(input.expression)
bolt.buildBolt();
args.isValidResult = True
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class BoltCommandDestroyHandler(adsk.core.CommandEventHandler):
def __init__(self):
super().__init__()
try:
# when the command is done, terminate the script
# this will release all globals which will remove all event handlers
adsk.terminate()
except:
if ui:
class BoltCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
def __init__(self):
super().__init__()
try:
cmd = args.command
cmd.isRepeatable = False
onExecute = BoltCommandExecuteHandler()
cmd.execute.add(onExecute)
onExecutePreview = BoltCommandExecuteHandler()
cmd.executePreview.add(onExecutePreview)
onDestroy = BoltCommandDestroyHandler()
cmd.destroy.add(onDestroy)
# keep the handler referenced beyond this function
handlers.append(onExecute)
handlers.append(onExecutePreview)
handlers.append(onDestroy)
#define the inputs
inputs = cmd.commandInputs
#inputs = cmd.commandInputs
inputs.addStringValueInput('boltName', 'Bolt Name', defaultBoltName)
selectionInput1 = inputs.addSelectionInput('face1', 'Select Face', 'Select a planar face')
selectionInput1.setSelectionLimits(1,1)
selectionInput1.addSelectionFilter('PlanarFaces')
initBodyLength = adsk.core.ValueInput.createByReal(defaultBodyLength)
inputs.addValueInput('bodyLength', 'Body Length', 'cm', initBodyLength)
except:
if ui:
class Bolt:
def __init__(self):
self._boltName = defaultBoltName
self._bodyLength = adsk.core.ValueInput.createByReal(defaultBodyLength)
#properties
@Anonymous
def boltName(self):
return self._boltName
@boltName.setter
def boltName(self, value):
self._boltName = value
@Anonymous
def bodyLength(self):
return self._bodyLength
@bodyLength.setter
def bodyLength(self, value):
self._bodyLength = value
def buildBolt(self):
global newComp
newComp = createNewComponent()
if newComp is None:
ui.messageBox('New component failed to create', 'New Component Failed')
return
# Create a new sketch.
sketches = newComp.sketches
xyPlane = newComp.xYConstructionPlane
xzPlane = newComp.xZConstructionPlane
sketch = sketches.add(face1)
center = adsk.core.Point3D.create(0, 0, 0)
circles = sketch.sketchCurves.sketchCircles
# Add a circle to the sketch circles collection by using addByCenterRadius.
# The needed parameters are the center points and radius.
circle1 = circles.addByCenterRadius(adsk.core.Point3D.create(0, 0, 0), 7.62)
extrudes = newComp.features.extrudeFeatures
prof = sketch.profiles[0]
extInput = extrudes.createInput(prof, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
extInput.setDistanceExtent(False, self.bodyLength)
headExt = extrudes.add(extInput)
fc = headExt.faces[0]
bd = fc.body
bd.name = self.boltName
def run(context):
try:
if not design:
ui.messageBox('It is not supported in current workspace, please change to MODEL workspace and try again.')
return
commandDefinitions = ui.commandDefinitions
#check the command exists or not
cmdDef = commandDefinitions.itemById('Bolt')
if not cmdDef:
cmdDef = commandDefinitions.addButtonDefinition('Bolt',
'Create Bolt',
'Create a bolt.',
'./resources') # relative resource file path is specified
onCommandCreated = BoltCommandCreatedHandler()
cmdDef.commandCreated.add(onCommandCreated)
handlers.append(onCommandCreated)
inputs = adsk.core.NamedValues.create()
cmdDef.execute(inputs)
# prevent this module from being terminate when the script returns, because we are waiting for event handlers to fire
adsk.autoTerminate(False)
except:
if ui:
