DataFileFuture.uploadState is not updating when commandInputs are used in a plugin
sharas_s
sharas_s
Hello everyone,
I am trying to make a simple script that uploads a template document multiple times into F360 for later use. Stumbled into a strange issue when commandInputs are involved.
Attached example plugin (will appear under utilities/add-ins in F360) which should replicate the issue.
Made 2 buttons in this plugin: "Upload example CommandInput" and "Upload example simple"
Simple version just takes predefined values and upload local document multiple times in sequence with no problems and works great.
But I want to be able to change which local document to upload and the quantity. And when I add CommandInput  for that (in "Upload example CommandInput" button), it seems something strange happens in F360 and DataFileFuture.uploadState does not change its value even if you wait for a while. This results in an infinite loop and requires killing F360 and restarting it.  After restart, documents that the plugin was uploading are fully uploaded and I am able to open them.
While investigating this issue I couldn't pinpoint the exact command which causes this issue but it seems CommandInput somehow is related.
Maybe someone knows what could be the reason for this or is it a bug?
sharas_s
Maybe someone could have a look at this issue? @hanskellner @prainsberry
Rushikesh.kadam
@sharas_s In the latest Fusion release, I am able to change and upload the file to the required quantity. Tried with 5 quantities, and there was no problem with the upload.
Can you take the latest Fusion update and check if you are still facing the issue?
If my reply was helpful, please click the "Accept as Solution" button. It helps others get the answer quickly! A "Like" is always welcomed.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
sharas_s
Hey @Rushikesh.kadam , thank you for taking a look into this issue and sorry for a late reply.
I updated F360 (current version 2.0.13377) but it still hangs when I try uploading with CommandInputs.
Attached video showing it. After it hangs, I kill F360 and relaunch it to show that the file was uploaded once
[video]
Rushikesh.kadam
@sharas_s I am still not able to reproduce the case. Here is a recording of the steps I am following.
Can you help identify if anything I am missing?
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
sharas_s
It seems you did everything the same way I did. So maybe it is something specific to my PC, F360 setup. Any ideas what could help?
I tried clearing cache data but that didn't help
Jorge_Jaramillo
Hi @sharas_s ,
I had the same problem in my environment.  I'm running Fusion360's latest version "2.0.13377".
I made a change to check the status of the upload process not with the future flag, but instead with the dataFile.isComplete attribute. Other change I made was to send all files creations requests at once, and then make only one monitoring loop.  With this change both launchers (simple and commandInput) run successfully.
The conclusion I have is that the file status in the DataFileFuture.uploadState attribute is not updated, while the dataFile.isComplete attribute report the real status of the file.
This is code with the modifications I made in upload.py:
def upload_file(folder, filepath):
    Use DataFileFuture to check upload state
    future = folder.uploadFile(filepath)
    adsk.doEvents()
    return future
    n = 0
    while True:
        n += 1
        futil.log(f'folder: {folder.name}, state: {future.uploadState}, valid: {future.isValid} - {n}')
        if future.uploadState == adsk.core.UploadStates.UploadFinished:
            return
        elif future.uploadState == adsk.core.UploadStates.UploadFailed:
            raise Exception("upload failed")
        adsk.doEvents()
def templates(template, quantity=1):
    app = adsk.core.Application.get()
    folder = app.data.activeProject.rootFolder
    name_template = 'blank'
    regex = re.compile( r'v\d+' )  # regex to find version number in filename
    template_version = regex.findall( template )[ 0 ]
    template_filepath = os.path.join( config.TEMPLATE_FOLDER, template ).replace( "\\", "/" )
    futureDict = {}
    folderDict = {}
    folder_idx = 1
    for _ in range(quantity):
        # find unused indexes
        used_folder_names = [ doc.name for doc in folder.dataFolders]
        while f'{name_template}_{folder_idx}' in used_folder_names:
            folder_idx += 1
        # create folder for template
        blank_name = f'{name_template}_{folder_idx}'
        blank_folder = folder.dataFolders.add(
            f"{blank_name}"
        adsk.doEvents()
        left_blank_folder = blank_folder.dataFolders.add(
            f"Left_{template_version}"
        adsk.doEvents()
        right_blank_folder = blank_folder.dataFolders.add(
            f"Right_{template_version}"
        adsk.doEvents()
        # start uploading template
        # Option 1
        k = f'L{_}'
        futureDict[k] = upload_file( left_blank_folder, template_filepath)
        folderDict[k] = left_blank_folder
        v = folderDict[k]
        k = f'R{_}'
        futureDict[k] = upload_file( right_blank_folder, template_filepath)
        folderDict[k] = right_blank_folder
        v = folderDict[k]
    n = 0
    while True:
        adsk.doEvents()
        succ = 0
        fail = 0
        comp = 0
        status = ''
        n += 1
        for k,v in futureDict.items():
            r = v.uploadState
            if r == adsk.core.UploadStates.UploadFinished:
                succ += 1
            elif r == adsk.core.UploadStates.UploadFailed:
                fail += 1
            df = adsk.core.DataFolder.cast(folderDict[k])
            if df and df.dataFiles and df.dataFiles.count and df.dataFiles.item(0):
                if df.dataFiles.item(0).isComplete:
                    x = 'T'
                    comp += 1
                else:
                    x = 'F'
            else:
                x = ' '
            status += f'{k} {r}{x[0]}  '
        futil.log(f'{status} {comp} {n}')
        if succ + fail == quantity * 2 or comp == quantity * 2:
            return
Take a look at the output messages where I print the status of each file it finds in the waiting loop:
In yellow the files ID, in orange the future attribute and in green the dataFile.isComplete attribute.
Notice all orange equal to 0 (UploadProcessing) while the greens vary on each iteration.
First run was made with commandInput while second was made with simple script.
I hope this could help support team to check why the inconsistency in the two attributes is happening.
Let me know if it works for you on your environment.
Jorge
