Customizing post processor for Mitsubishi M70
Hello everyone,
   I just began working with Fusion 360 and am by no means able to edit my post processor….was wondering if a kind soul could help me customize my post processor because the generic version is really not quite what I like.....I am using the generic version of MITSUBISHI (milling)....my controller is a Mitsubishi M70
Here is an example of what my actual post generates as a G-code versus a configuration I am using in Mastercam which generates a satisfactory G-code for my requirements....
I would like to change the following details....
Line N20   add G28 Y0. to the line following home command (G91 G28 Z0.)
Line N25   put the G90 on the same line as the G54 (line45) , after calling the tool
Line N140   put M09 and M05 before homing the axes (G28)
Between Line N140 and N150  move operation description to after the M01
Remove X0. In final G28 command before the M30  (in this example I manually dropped it to the next line)
**if possible**
- re-arrange tool list info to show the tool first, followed by its description
- list maximum and minimum operation depth for all tools
Would kindly appreciate any help,
Glenn
BrianEkins
This forum is about using the Fusion API. You'll have better luck getting help with a post processor on the manufacturing forum.
https://forums.autodesk.com/t5/fusion-360-manufacture/bd-p/2070
Brian Ekins
Thanks Brian.... i'll try to repost there....sorry for the inconvenience...
