CustomGraphicsMesh malfunctioning after Sep. Fusion 360 Update
Haowei.Tan
718 Visites
4 Réponses
Message 1 sur 5
Haowei.Tan
Hi All,
I have been using CustomGraphicsMesh with CustomGraphicsVertexColorEffect to create colorbar under Desing mode, and it worked quite well without any problem. However after the latest Sep. update, the CustomGraphicsMesh stopped to give the correct vertex color.
To reproduce this issue, please refer to the code below.
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        design = adsk.fusion.Design.cast(app.activeProduct)
        component = design.rootComponent
        group = component.customGraphicsGroups.add()
        coordinates = adsk.fusion.CustomGraphicsCoordinates.create([
            # upper left triangle
            -5, -5, 0,
            -5,  5, 0,
             5,  5, 0,
            # lower right triangle
            -5, -5, 0,
             5,  5, 0,
             5, -5, 0,
        coordinates.colors = [
            # royal
              0, 128, 255, 255,
              0, 128, 255, 255,
              0, 128, 255, 255,
            # orange
            255, 128,   0, 255,
            255, 128,   0, 255,
            255, 128,   0, 255,
        indices = [
            0, 1, 2,
            3, 4, 5,
        customMesh = group.addMesh(coordinates, indices, [0, 0, 1] * (coordinates.coordinateCount // 3), indices)
        customMesh.color = adsk.fusion.CustomGraphicsVertexColorEffect.create()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
It should (and used to) display something as follows (this is something I created for demo purpose):
And after the update, this code snippet could create a square but not with the correct vertex colors.
My product hash is 3f77c28c02b1b466e9d910ef562e48d42f47cc2b.
Is anyone experiencing similar issues?
Many thanks for your time.
Tan
0 J'aime
719 Visites
4 Réponses
Message 2 sur 5
BrianEkins
I'm able to reproduce the problem and will see that a bug gets filed.
Brian Ekins
Inventor and Fusion 360 API Expert
Website/Blog: https://EkinsSolutions.com
Message 3 sur 5
Haowei.Tan
Hi Brian,
Thank you very much for your quick response! Looking forward to your further updates.
0 J'aime
Message 4 sur 5
Haowei.Tan
Hi Brian,
We are happy to confirm that in the latest Fusion360 major update this issue has been addressed and the bug is fixed now!
Thank you for your kind help!
Tan
0 J'aime
Message 5 sur 5
BrianEkins
That's great new. Thanks for letting me know.
Brian Ekins
0 J'aime
