Custom Table script
Custom Table script
linas
Custom Table script
linas
Hello!
I'm getting into scripts via Fusion API and my goal was to inject part numbers, description and quantity into custom tables (i'm doing that because i have a Fusion Add-in called JoinerCad and it has an another system of assigning material and so on).
Now i found that adsk.drawing.CustomTable - add() ignores rowCount/columnCount,
updateCellData() always returns "Unknown exception"
And regardless of what was set on the input of CustomTable created via sheet.customTables.add(inp) always has rowCount=0 and columnCount=0. updateCellData(row, col, string) always returns "1 : Unknown exception".
If you have any info about or have succesfully put info into the custom table, would gladly hear from you 🙂
I could also send you the code 🙂
Thank you
kandennti
Hi @linas -san.
Unfortunately, the `adsk.drawing.CustomTable` property does not currently exist.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-CEC1BA2F-1AA7-4D7D-9C98-410637FEDB1E
At present, there is very little support for Fusion 360's Drawing-related APIs.
However, I recall an Autodesk representative commenting earlier this year that they “plan to expand the Drawing API by the end of the year,” so support may improve in the future.
linas
Hello kandennti!
Thank you for reply! I tried poking around what can the adsk.drawing object can offer in terms of table/custom table and you are right it is very limited in that sense! 😄
I used these two methods: sheet.customTables.createInput() and sheet.customTables.add
Lets hope its true and will expand on the Drawing API!
bhavani_sankuratri
Hi @linas
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
Let us know how we did on Trustpilot.
Bhavani Sankuratri
linas
If anyone uses JoinerCAD plugin by any chance (because i needed a purchased items component table), i have found a way to create a custom table that pastes itself into the clipboard and all you need to do is CTRL+V 🙂
Write me and i'll be happy to share the code 😄
