Custom chamfer for polygon
On picture AB=BC=5mm
Diameter circle in polygon =110mm
What  coordinates A or B?
marshaltu
I am not clear what's your issue? You can probably use "Chamfer feature" API to create custom chamfer with "two distances" or "distance and angle" option. Or you can create an extrude feature with the sketch to cut the "Polygon" body to get custom "chamfer" as well.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-f0eae304-aaca-4ced-b8c0-3b679d7c1f3d
Marshal
Marshal Tu
Fusion Developer
I need my chamfer features, don't fusion "ChamferFeatures". All I need calculate point A or B.
