css grid in palettes
VismantasKizelis
VismantasKizelis
Hello
With the latest Fusion 360 our palettes collapsed, because css -rid (display:grid) is not supported in new web browser palettes. We hope that it is just a temporary flaw.
Btw: what engine Fusion 360 is using to render the html in palettes?
akonovalenko
To check Fusion palette engine you can easily navigate your custom palette to the online checkers like
'http://www.browser-info.net' 'https://html5test.com/' 'https://ruanyf.github.io/es-checker/'
here are results of my test on Windows version of Fusion 360
Please pay attention that for MAC environment the results will be different.
VismantasKizelis
Hello akonovalenko
Fusion 360 api used chrome to render the palettes, but soon it will not be supported. I suppose you were not using the new web browser. Take a look at the palettes()->add() function declaration:
/// Creates a new Palette.
/// id : The unique id for this palette. The id must be unique with respect to all of the palettes.
/// name : The displayed name of this palette. This is the name visible in the user interface.
/// htmlFileURL : Specifies the url to the HTML file that will be displayed in the pallete. This can be a local file or on the web.
/// isVisible : Specifies if the palette is initially visible or not. It's useful to create it invisisibly, change other desired
/// properties and then use the isVisible property to finally make it visible to the user.
/// showCloseButton : Specifies if a "Close" button should be displayed on the palette to allow the user to easily close it.
/// isResizable : Specifies if the palette can be resized by the user or not.
/// width : Specifies the width of the palette in pixels. If no width is specified a default width will be used.
/// height : Specifies the height of the palette in pixels. If no height is specified a default height will be used.
/// useNewWebBrowser : Specifies true to use new browser in the palette. This is false by default to support existing clients.
/// Support for old browser is deprecated and will be taken out soon.
/// Returns the newly created palette or null in the case the creation failed.
Ptr add(const std::string& id, const std::string& name, const std::string& htmlFileURL, bool isVisible, bool showCloseButton, bool isResizable, int width = 200, int height = 200, bool useNewWebBrowser = false);
I got same results as yours at browser-info.net when useNewWebBrowser == false, but the browser is not identified when useNewWebBrowser == true
goyals
We are using QtWebBrowser as new web browser for palette. Previously we were using Chromium on Windows and Mac OSX WebKit on Mac. Let us know If you notice any issue while using new browser. Thanks.
Shyam Goyal
Sr. Software Dev. Manager
