Creative solution for bounding box of flat pattern
Hello all,
It seems that sheet metal is not included in the api. Quite a bummer, as I'm working on an add-in that generates a BOM: It would mean that it is impossible to get the dimensions of a sheet, as you can only retrieve the bounding box of the folded body, not of the unfolded body.
But as I've been surprised several times by the creativity of some of the community members here, I thought that I should ask here before I give up. Does anyone have a suggestion on how to retrieve the bounding box of a flat pattern? Maybe trough usage of ui commands?
Thanks!
OceanHydroAU
kandennti
Hi @Anonymous -San.
Flat patterns also have 3D data when flattened.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-AA00DEBE-61BB-4FF1-AE0D-EDF71A82C183
It can be obtained from the BoundingBox of this Body.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        root: fusion.Component = des.rootComponent
        flatPattern: fusion.FlatPattern = root.flatPattern
        if not flatPattern:
            ui.messageBox("No flat pattern")
            return
        flatBody: fusion.BRepBody = flatPattern.flatBody
        bBox: core.BoundingBox3D = flatBody.preciseBoundingBox
        flatSize = [
            abs(bBox.maxPoint.x - bBox.minPoint.x),
            abs(bBox.maxPoint.y - bBox.minPoint.y),
            abs(bBox.maxPoint.z - bBox.minPoint.z),
        unitsMgr: core.UnitsManager = des.unitsManager
        flatSizeStr = [unitsMgr.formatValue(v) for v in flatSize]
        ui.messageBox(" x ".join(flatSizeStr), "Flat Pattern Size")
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Since this Body can also be exported, we have created this add-in and published it.
https://github.com/kantoku-code/Fusion360_BLACKSMITH
