creating sphere with temporary BRep manager
I am migrating some of my design to use of temporary BRep manager in baseFeature.
At createSphere() api, I noticed that sphere created at non-origin point jumps to origin right after finishEdit() is called.
Is there anyone who experienced the same issue ? I would appreciate if someone could help me out.
An example script is attached. In this example sphere at (5,0,0) jumps to (0,0,0)
kandennti
@Anonymous さん こんにちは
I was able to reproduce it as well.
After running the script, the body position in question and the "Canter of Mass" value are clearly different.
Once saved and then reopened the document, the body appears to be in the correct position.
This is probably a display bug.
If you're in a hurry, since "temporaryBRepManager.transform" seems to be working, you'll have no choice but to create such a function to deal with it.
def initTmpBrepSphere(
    center :adsk.core.Point3D,
    radius :float) -> adsk.fusion.BRepBody:
    tmpMgr = adsk.fusion.TemporaryBRepManager.get()
    pntZero = adsk.core.Point3D.create(0, 0, 0)
    sphere = tmpMgr.createSphere(pntZero, radius)
    if pntZero.isEqualTo(center):
        return sphere
    vec = pntZero.vectorTo(center)
    mat = adsk.core.Matrix3D.create()
    mat.translation = vec
    tmpMgr.transform(sphere, mat)
    return sphere
kandennti
 Hi @kandennti
Your workaround solution works, thank you very much for solving the problem so quickly!
BrianEkins
I also recently ran into this problem and have been told it's been fixed and we should see it in the next big update.
Brian Ekins
