- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm writing a script that creates lots of cylinders, between points in space. As far as I can tell, Lofts are the way to go for this. I have code that works, but it gets incredibly slow - I can make 10 cylinders no problem, but when I try to make 30, it hangs for several minutes. Is this just poor API performance? Is there a more efficient way to make cylinders?
def create_bond(rootComp,bond,r): start = bond.start.get_point() end = bond.end.get_point() # Create sketch #p = adsk.core.Plane.create(bond.start.get_point(), bond.start.get_point().vectorTo(bond.end.get_point())) planes = rootComp.constructionPlanes planeInput = planes.createInput() line_sketch = rootComp.sketches.add(rootComp.xYConstructionPlane) # Draw a line to use as the axis of revolution. lines = line_sketch.sketchCurves.sketchLines line = lines.addByTwoPoints(start, end) # Create a path and let it find connected curves automatically path = rootComp.features.createPath(line) planeInput = rootComp.constructionPlanes.createInput() # you could also specify the occurrence in the parameter list planeInput.setByDistanceOnPath(path, adsk.core.ValueInput.createByReal(0)) plane1 = rootComp.constructionPlanes.add(planeInput) sketch1 = rootComp.sketches.add(plane1) circles = sketch1.sketchCurves.sketchCircles circle1 = circles.addByCenterRadius(adsk.core.Point3D.create(0, 0, 0), r) # Create the End Loft Sketch Profile planeInput.setByDistanceOnPath(path, adsk.core.ValueInput.createByReal(1)) plane2 = rootComp.constructionPlanes.add(planeInput) sketch2 = rootComp.sketches.add(plane2) circles = sketch2.sketchCurves.sketchCircles skPosition = sketch2.modelToSketchSpace(end) circle2 = circles.addByCenterRadius(skPosition, r) profile0 = sketch1.profiles.item(0) profile1 = sketch2.profiles.item(0) # Create loft feature input loftFeats = rootComp.features.loftFeatures loftInput = loftFeats.createInput(adsk.fusion.FeatureOperations.NewBodyFeatureOperation) loftSectionsObj = loftInput.loftSections loftSectionsObj.add(profile0) loftSectionsObj.add(profile1) loftInput.isSolid = False try: # Create loft feature loftFeats.add(loftInput) except: print("couldn't loft {} to {}".format(bond.start, bond.end)) #print(traceback.format_exc())
