Creating A Sweep Feature without a Guide Line F360 API Error
jakedbirk
jakedbirk
I am having a problem using the API to sweep a profile along a path without a guideline which does not through any errors using the GUI.
This script will eventually be moved to my Add-In and is supposed to take a 2D profile, angle it to match the pitch of a staircase and sweep the profile along the path to create a returned mitered handrail. I've attached a picture of me using the GUI to make the final sweep.
I've been getting errors but I cannot determine why. I've already spent a good amount of time playing around with the script over the course of a few days and don't seem to be getting very far.
The troublesome part of this script begins on line 100.
Also: this script uses a 2d.dxf file which is a very important part of the final outcome (where the user should be able to select from a list of GUI-created profiles.  So I've attached the script folder with that file.
Code Snipet:
import adsk.core, adsk.fusion, adsk.cam, traceback, os, math
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        design = adsk.fusion.Design.cast(app.activeProduct)
        #Pull A Function I Use in Other Parts of My Add-in
        def addInchSketchPoint(sk: adsk.fusion.Sketch, x: float, y: float, z: float) -> adsk.fusion.SketchPoint: #This Function Was Written By Brian Etkins
            pnt = adsk.core.Point3D.create(x * 2.54, y * 2.54, z * 2.54)
            return sk.sketchPoints.add(pnt)
        #Pull Up File Name:
        pathProfile = os.path.join(os.path.dirname(os.path.abspath(__file__)), 'resources/3dData/','profile2x4.dxf')
        #Info Pulled From Flight & User
        unitRise = 8
        unitRun = 10
        treadOverhang = 1.25
        topOfRailHeight = 36
        railFromWall = 1.25
        riseCount = 15
        #Calculated Variables
        slope = math.atan(unitRise/unitRun)
        zIncreaseOverhang = math.tan(slope)*treadOverhang
        #Info Pulled From Profile (How exactly this happens is TBD (Maybe Bounding Box is a Good Idea))
        profileHeight = 1.5
        profileWidth = 3.5
        #Grabbing the Root Component
        compRoot = design.rootComponent
        #import manager
        importMgr = app.importManager
        impOptionsProfile = importMgr.createDXF2DImportOptions(pathProfile,compRoot.xYConstructionPlane) #NOTE: Although this sketch ends up in the
        importMgr.importToTarget(impOptionsProfile,compRoot)
        #Grab the sketch and create an object collection with all of its objects
        sketch = compRoot.sketches.item(compRoot.sketches.count-1)
        all = adsk.core.ObjectCollection.create()
        for c in sketch.sketchCurves:
            all.add(c)
        for p in sketch.sketchPoints:
            all.add(p)
        #First Rotation along X axis
        axis = sketch.xDirection #Grabs vector (1,0,0) (in the sketch)
        axis.transformBy(sketch.transform) #Makes the vector (1,0,0) compared to the root component
        origin = sketch.origin #Grabs the sketch origin
        origin.transformBy(sketch.transform) #Makes sure its the root component origin
        mat = adsk.core.Matrix3D.create()
        mat.setToRotation(math.pi /2, axis, origin)
        sketch.move(all, mat)
        #Rotation Along Z Axis (Sketch is now effectively placed in the yZPlane but all the math is consitent with yZ plane)
        axis = adsk.core.Vector3D.create(0,0,1)
        mat.setToRotation(math.pi/2,axis,origin)
        sketch.move(all,mat)
        #Rotation to Rake Angle
        mat.setToRotation(slope, axis, origin)
        #Raise Sketch to TopOfRailHeight above Nosing Line
        vectorRaiseSketch = adsk.core.Vector3D.create(0,-treadOverhang*2.54,unitRise*2.54+topOfRailHeight*2.54)
        transform = adsk.core.Matrix3D.create()
        transform.translation = vectorRaiseSketch
        sketch.move(all,transform)
        #Pull Centroid From Rail Profile
        profileRail = sketch.profiles.item(sketch.profiles.count -1 )
        profRailY = profileRail.areaProperties().centroid.y
        #Calculate Point Values
        xOffsetOuter = 0
        xOffsetInner = profileWidth/2+railFromWall
        #Create Points for Rail
        pointRailBottom = addInchSketchPoint(sketch,xOffsetOuter,0,unitRise+topOfRailHeight+zIncreaseOverhang)
        pointRailMiterBottom = addInchSketchPoint(sketch,xOffsetInner,0,unitRise+topOfRailHeight+zIncreaseOverhang)
        pointRailMiterTop = addInchSketchPoint(sketch,xOffsetInner,pointRailMiterBottom.geometry.y/2.54 + (riseCount-1)*unitRun,pointRailMiterBottom.geometry.z/2.54 + (riseCount-1)*unitRise)
        pointRailTop = addInchSketchPoint(sketch,xOffsetOuter,pointRailMiterTop.geometry.y/2.54,pointRailMiterTop.geometry.z/2.54)
        #Create Lines Connecting Points
        lineBottomMiter = sketch.sketchCurves.sketchLines.addByTwoPoints(pointRailBottom,pointRailMiterBottom)
        lineMiddleRail = sketch.sketchCurves.sketchLines.addByTwoPoints(pointRailMiterBottom,pointRailMiterTop)
        lineTopMiter = sketch.sketchCurves.sketchLines.addByTwoPoints(pointRailMiterTop,pointRailTop)
        #TODO: Add Sweep
        col = adsk.core.ObjectCollection.create()
        col.add(lineBottomMiter)
        col.add(lineMiddleRail)
        col.add(lineTopMiter)
        path = adsk.fusion.Path.create(col,True)
        inpSweep = compRoot.features.sweepFeatures.createInput(profileRail,path,3)
        inpSweep.guideRail = None
        compRoot.features.sweepFeatures.add(inpSweep)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Thank You for Reading & Helping!
Jorge_Jaramillo
Hi @jakedbirk ,
In this post https://forums.autodesk.com/t5/fusion-360-api-and-scripts/error-when-creating-a-sweep/td-p/11735184
@BrianEkins found the problem.
So, you just need to copy line 85 into 113 and your code will run.
It is a kind of bug if you get the profile before you make the path.
Jorge Jaramillo
Software Engineer
jakedbirk
Thank you so much, that solution worked like a charm!
Perhaps Autodesk should not this error in the documentation to help other programmers in the future.
Also thank you again to @BrianEkins who always seems to play a role in the solutions to my F360 API problems!
