creating a sub command from API
pludikar
pludikar
In the manufacturing workspace under 2D contour | geometry tab, there's an option to select a contour via a chain in the table toolbar.  Clicking that chain button appears to create a sub command dialog, while dimming the controls on the main command.
Can this be done via the API?
I know that doing a "commandDefinition.execute()" isn't supported in this instance - it results in the active command terminating!
regards
Peter
I'm not an expert, but I know enough to be very, very dangerous.
Life long R&D Engineer (retired after 30+ years in Military Communications, Aerospace Robotics and Transport Automation).
boopathi.sivakumar
Hi @pludikar
Currently Fusion API don't have support for this type of sub commands. Its interanal only at this moment
Boopathi Sivakumar
Principal Manufacturing Engineer
pludikar
Thanks - I suspected as much. If you don't already have it on your road map, could you please add it.
Regards
Peter
