Creating a SketchArc
balunist
balunist
I could use some help.  Sorry in advance since this is probably something very basic to some.
I want to create an arc in a sketch.  I have the startPoint, endPoint and radius.   There are two possible apis available.
sketchArcs.addByCenterStartSweep(centerPoint, startPoint, sweepAngle)
and
sketchArcs.addByThreePoints(startPoint, alongPoint, endPoint)
I was surprised that there was not a more direct route, giving the endpoints, radius and a direction point the way sketch.offset is handled.  So I've been trying to use the addByCenterStartSweep and I'm struggling.
To get the centerPoint and sweep I was thinking (very likely wrongly) that I needed to do the following
  • get the midPoint between startPoint and endPoint
  • create a vector from midPoint to startPoint called it lineVector
  • create a Matrix3D call it rotate90 and setToRoation(pi / 2, axis, midPoint).  ?? axis = Z axis
  • rotate lineVector  90 degrees  with lineVector.transformBy(rotate90)
  • resize lineVector to radius,  lineVector.scaleBy(radius / lineVector.length)
  • create centerPoint using the lineVector's x,y,z. ???
  • create vector1 = centerPoint.vectorTo(startPoint) and vector2 = centerPoint.vectorTo(endPoint)
  • sweep = vector1.angleTo(vector2)
  • create the arc with sketchArcs.addByCenterStartSweep(centerPoint, startPoint, sweep)
kandennti
Hi @balunist .
If the only conditions are startPoint, endPoint, and radius, four arcs are candidates. I think that is why the method cannot be prepared.
I have created a sample that finds 4 transit points and creates all arcs.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
import math
import itertools
def run(context):
    ui: adsk.core.UserInterface = None
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        msg: str = 'Select Sketch Point(start)'
        selFilter: str = 'SketchPoints'
        sel: adsk.core.Selection = selectEnt(msg, selFilter)
        if not sel:
            return
        startPnt: adsk.fusion.SketchPoint = sel.entity
        msg = 'Select Sketch Point(end)'
        sel = selectEnt(msg, selFilter)
        if not sel:
            return
        endPnt: adsk.fusion.SketchPoint = sel.entity
        length = startPnt.worldGeometry.distanceTo(
            endPnt.worldGeometry
        unitMgr: adsk.core.UnitsManager = des.unitsManager
        msg = 'Enter the radius.\n'
        msg += f'({unitMgr.formatInternalValue(length * 0.5)} or more)'
        res, cancelled = ui.inputBox(
            msg,
            str(
                    unitMgr.convert(
                    length * 0.5,
                    unitMgr.internalUnits,
                    unitMgr.defaultLengthUnits
                ) + 1
        if cancelled:
            return
        if not isFloat(res):
            return
        radius = unitMgr.convert(
            float(res),
            unitMgr.defaultLengthUnits,
        if radius < length * 0.5:
            return
        createTwoPointsRadiusArcs(
            startPnt,
            endPnt,
            radius,
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def isFloat(s) -> bool:
    try:
        float(s)
        return True
    except:
        return False
def createTwoPointsRadiusArcs(
    startPnt: adsk.fusion.SketchPoint,
    endPnt: adsk.fusion.SketchPoint,
    radius: float):
    def getMidPoint(
        sPnt: adsk.core.Point3D,
        ePnt: adsk.core.Point3D) -> adsk.core.Point3D:
        return  adsk.core.Point3D.create(
            (sPnt.x + ePnt.x) * 0.5,
            (sPnt.y + ePnt.y) * 0.5,
            (sPnt.z + ePnt.z) * 0.5,
    def getOffsetVector(
        p1: adsk.core.Point3D,
        p2: adsk.core.Point3D,
        vec: adsk.core.Vector3D) -> adsk.core.Vector3D:
        v: adsk.core.Vector3D = vec.crossProduct(
            p1.vectorTo(p2)
        v.normalize()
        return v
    def getCenterPoints(
        mPnt: adsk.core.Point3D,
        r: float,
        offsetVec: adsk.core.Vector3D) -> list:
        l1 = sPnt.distanceTo(mPnt)
        theta = math.acos(l1 / r)
        vec: adsk.core.Vector3D = offsetVec.copy()
        vec.scaleBy(
            math.tan(theta) * l1
        centers = []
        for scl in [1, -1]:
            v: adsk.core.Vector3D = vec.copy()
            v.scaleBy(scl)
            p: adsk.core.Point3D = mPnt.copy()
            p.translateBy(v)
            centers.append(p)
        return centers
    def getTransitPoints(
        centers: list,
        r: float,
        vec.scaleBy(r)
        vecs = []
        for s in [1, -1]:
            v.scaleBy(s)
            vecs.append(v)
        pnts = []
        for pnt, v in itertools.product(centers, vecs):
            p = pnt.copy()
            p.translateBy(v)
            pnts.append(p)
        return pnts
    def createArcs(
        skt: adsk.fusion.Sketch,
        ePnt: adsk.core.Point3D,
        transitPoints: list):
        arcs: adsk.fusion.SketchArcs = skt.sketchCurves.sketchArcs
        arcLst = []
        skt.isComputeDeferred = True
        for mPnt in transitPoints:
            p1: adsk.core.Point3D = skt.modelToSketchSpace(sPnt)
            p2: adsk.core.Point3D = skt.modelToSketchSpace(mPnt)
            p3: adsk.core.Point3D = skt.modelToSketchSpace(ePnt)
            arcLst.append(arcs.addByThreePoints(p1, p2, p3))
        skt.isComputeDeferred = False
    skt: adsk.fusion.Sketch = startPnt.parentSketch
    sPnt: adsk.core.Point3D =  startPnt.worldGeometry
    ePnt: adsk.core.Point3D =  endPnt.worldGeometry
    # midPoint
    midPnt: adsk.core.Point3D = getMidPoint(sPnt, ePnt)
    # offset vector
    vec: adsk.core.Vector3D = getOffsetVector(
        sPnt,
        ePnt,
        skt.xDirection.crossProduct(
            skt.yDirection
    # center points
    centers = getCenterPoints(
        sPnt,
        midPnt,
        radius,
        vec
    # transit points
    transitPnts = getTransitPoints(
        centers,
        radius,
        vec
    # arcs
    createArcs(
        skt,
        sPnt,
        ePnt,
        transitPnts
def selectEnt(
        msg: str,
        filterStr: str) -> adsk.core.Selection:
    try:
        app = adsk.core.Application.get()
        sel = ui.selectEntity(msg, filterStr)
        return sel
    except:
        return None
balunist
Kandennti,
Excellent, thank you much!!   So some more background on the reason for my question.   I'm trying to gain a better understanding why an SVG file that I created is being misinterpreted by the sketch.importSVG api for which a fusion defect has been created.   I hoping to see the defect fixed soon since it is needed for some optimization for my add-in.
My goal is to perform a round trip by importing the SVG and you have provided the last piece to the puzzle, the Arc.   I did leave out some additional known arguments in my description,  the large-arc-flag and sweep-flag, which would narrow the 4 possible arcs you created down to one.
A rx ry x-axis-rotation large-arc-flag sweep-flag
